What is this plug
Discussion in 'The Garage' started by NoSmog73, Jan 13, 2004.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    I know the one with the 2 prongs is nutral (s/p) but what is the other fitting for...almost looks like a speedo but I thought the speedo was in the TC..The fitting has a rubber outter with a "piece" that looks like the middle of a speedo..Any thoughts.
    [​IMG] [​IMG] [​IMG]
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Was it originally a 2wd tranny? Maybe a later model 465. I know they put them in the 88up trucks until they switched to the 5 speed.
    Whatever it is, thats one of the cleanest I've seen in a while /forums/images/graemlins/grin.gif
    John
  3. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    It came out of a 1970-72 blazer with the org 205 Where can I run the tranny #'s to see if the PO changed it maybe... /forums/images/graemlins/thumb.gif
  4. dyeager535
    26,979
    I suspect that may be involved in some sort of 70's spark advance setup, similar to what was on some TH350's. I would be willing to bet that whatever it is, tells something else when the transmission is in one particular gear.
    A LATE 465 will have an aluminum top cover, FWIW, but even on those I don't think they used that switch.
  5. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Interesting, I've heard of that now that I think about it.. Could be what it is..
    I should have remembered that /forums/images/graemlins/tongue.gif /forums/images/graemlins/smile.gif
    John
  6. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Hey thanks guys..
    I think you are right on the spark control thingy..I took it out and there is a rod that moves under the switch that makes contact with the ball on the bottom of the switch and moves the ball up into the switch when contact is made..
    And how is that for clean..Thanks again Scott
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    TCS system, for low and forward range, retards timing, yes they had that back then too
    aluminum top were the NP435C and NP435CR trannies, another top loader tranny, cept built by NP, and also Warner made a top loader tranny also but i dont know if it was aluminum top or not, it was also optional for 67-72 years at minimum, i would have to look in GM sheets again to get model number and ratios
  8. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    hes right again
    69k5
  9. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Thanks guys...
    Now, Does anyone know where I can run the tranny #'s to get the right year of this tranny...Thanks /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  10. dyeager535
    26,979
    The later 465's had aluminum tops, after about '88 or so IIRC.
  11. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Mike, I thought so said the tranny and T-case were a matched pair, if so the T-case was a 3-16-70 production if you forgot already.
  12. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Reverse lamp switch ?
