What is this sensor for?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BayouBlazer88, Jul 7, 2003.
  1. BayouBlazer88
    BayouBlazer88 1/2 ton status
    Jul 31, 2002
    353
    Lafayette, LA
    Pulled out the engine about a week ago and noticed yesterday a sensor on the passenger side of the block that bolts to the coolant passage. The weird thing is that the wire coming out of it was just connected to one of the starter bolts. I doubt it was doing much good because when I pulled it out, no coolant came out since the block was so full of coolant residue (I had to poke a screwdriver through the hole to let the coolant come out). Anyway, what is this sensor and where is it supposed to connect? so that I can buy a new one and connect it correctly.
  2. crazykev4x4
    crazykev4x4 1/2 ton status
    Jun 30, 2003
    430
    Watertown,Wisconsin
    its the knock sensor . was it connected by the starter or did someone catch the wire and pinch it off when they put a starter in .
  3. BayouBlazer88
    Jul 31, 2002
    353
    Lafayette, LA
    it was wrapped around the end of the starter bolt (the part where you put your socket).
  4. crazykev4x4
    Jun 30, 2003
    430
    Watertown,Wisconsin
    if it was my truck i would find the other part if the wire and repair it
    Kevin /forums/images/graemlins/k5.gif
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    dont need to worry about it or the wire if ther eis no EST system left in the turck, IE emissions equipment for electronic controlled carb and electronically controlled advance HEI dizzy
  6. dyeager535
    26,977
    If it's an '88, it's TBI. Fix the wire.
  7. BayouBlazer88
    Jul 31, 2002
    353
    Lafayette, LA
    I know I need to hook it up, but I don't know WHERE to hook it up to. I'll look for a loose wire around the top of the engine but does anyone know what color it is or where the other end might be? Thanks guys.
    -Oh and just curious, what does a knock sensor do and what does the computer do when the sensor sends a signal to it? Also, if that's the knock sensor, then what sensor is on the driver side cylinder head between the #1 and #3 exhaust ports?
  8. crazykev4x4
    Jun 30, 2003
    430
    Watertown,Wisconsin
    coolant temp sensor for the gauge /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
    Kevin
