What is this sound??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5thatShmobs, Mar 15, 2003.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Today it showed up. Under acceleration, I get this "ticking" sound that changes in speed in time with the engine RPM. (e.g. The more pedal, the faster the "ticking" gets.) I sounds like its definitely coming from under the truck, but I have no idea where. I know this is minimal info to diagnose anything, but I was hoping someone may have heard this kind of sound and figured out what it was.
  2. Ryan2286
    Ryan2286 Registered Member
    Nov 7, 2002
    32
    South Suburbs of Chicago
    does it do it only when in gear or will it make the noise in park or neutral as well?
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Bad lifter, exhaust leak, or a broken flex plate. A bad lifter isn't treally a ticking noise. An exhaust leak will show some soot if your lucky. I'd be willing to bet on a flex plate tho. All of my tranny mounting bolts fell out and the tranny was hanging. Whenever I'd apply the gas it would go away. It really had me stumped til I happened to notice 1 bolt missing then 2 then 3.......I'd pull the inspection cover and try to get a peek in there. Good Luck
  4. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I had a leaky exhaust manifold gasket that made the "tick.....tick" noise....
  5. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    i stand behind my pipes and get black rings on my pants
    soot?
  6. nevercomplete
    nevercomplete 1/2 ton status
    Dec 25, 2001
    309
    Beaufort, South Carolina
    My truck does the same, it is an exhaust leak on mine.
    Jon
  7. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    i've had 2 flexplates go and they start out as a tick then its a rattle after a while. if it gets worse i'd be willing to bet it's the flexplate.
  8. nevercomplete
    Dec 25, 2001
    309
    I'm not too good with noises /forums/images/graemlins/1zhelp.gif
    Jon
  9. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    Take a look at the flexplate. I had a similar problem on my '89 Sub, as well as on my friend's '91 Sub.
  10. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    sounds like the notorius muffler bearing the only way to fix it is ya gotta put beaver oil in your gas when ya fill up /forums/images/graemlins/grin.gif
    no seriously i vote for the exhaust leak
  11. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Its really hard to say... Our suburban was making that noise untill a couple of days ago and it turned out to be a cracked flex plate (which damaged the torque converter which contaminated the tranny which completely smoked the clutches... which left our sub stuck on pepper street near stanley motors there in san luis so feel free to go make sure that no one has been messing with it /forums/images/graemlins/crazy.gif.) What I'm getting at is that pulling the inspection cover off the tranny doesn't take long, but avoiding it can cause some catastrophic damage ($$$) if it is the flex plate and you catch it in time, autozone has new ones for $35 although it is a pain to change it, it's a lot cheaper than changing the whole tranny with it /forums/images/graemlins/frown.gif.
  12. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Im trying to figure out what might cause a bad flex plate... I just put in the new tranny with a new flex plate a couple months ago. And just to make absolutely sure... a flex plate is the same thing as what most call a flywheel, correct?
    Okay, so If I do pull the inspection cover, what am I looking for? Cracks? Im thinking that those would be in the middle of the flex plate, and it seems to me that you wouldnt be able to see the middle just by pulling that one cover below the TC.
    Oh and by the way, the sound just started today... I hope it hasnt been too long.
    As for the exhaust, it was done right before my eyes by a very good tech about a month ago, and the noise doesnt sound too much like exhaust.
  13. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Yes look for cracks radiating out from the center out to the edges, espescially near the big holes that are in the flex plate. I wish I had my digi camera still. The whole center of mine stayed on the truck and rest fell off when I pulled off of the crank. Looked like a big donut
  14. KShortell
    KShortell Registered Member
    Jun 11, 2001
    44
    Bel Air, Maryland
    "Under accelaration"-- makes me initially think of an exhaust manifold gasket. I had to replace mine a couple of times in a couple of years-- bolts kept loosening up on me- even with thread-locker. I think I'm going to see if I can get Stage 8 bolts that work with manifolds if I ever have to replace 'em again...
    I've not had a flexplate crack on me, but I did have one warp a bit, causing a driveline vibration. A warped one won't make a noise, although I bet a cracked one does! For more on mine and how I replaced it, see here: '86 350 Flexplate Replacement
    Good luck! I know that sounds can be really annoying. It tooke me a long time to pinpoint my problem. I fixed everything but the real problem first! /forums/images/graemlins/blush.gif
    Kevin
    /forums/images/graemlins/burb.gif
  15. Bob Hope
    Bob Hope Registered Member
    Feb 25, 2003
    14
    Pinconning, MI
    take the ace of spades out of your spokes! /forums/images/graemlins/rotfl.gif
  16. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    With the engine at idle, open the hood and look at your accesory belts. If you notice they "bounce" a little in harmony with the ticking sound, your flexplate is cracked and the bolts are hitting the inspection cover, as this condition progresses it will sound like a rod knock and you'll think your just about to lose an engine in Barstow Hell on a roadtrip to Disneyland. /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/rolleyes.gif
    Don't ask me how I know /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  17. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Alright well I just popped the inpection cover and the flywheel looks fine. I had a buddy crank the engine a few times and I didnt see any cracks or anything. I then went around all the bolts on the bellhousing to make sure they were all tight. I have a 700R4 with the support strut that goes from the t-case to the bottom right bolt on the bell housing, and that bolt head was broken off... again! A grade 8 bolt also. I dont know if the lack of support in that area has anything to do with my ticking sound, but it keeps breaking. This is my second strut, too. I broke my first one.
    Im in a real bind this time though... the entire bolt minus the head is still threaded into the block. I dont know how Im going to get it out. I cant really use an easy-out drill bit or something because its too cramped of a space to get a drill in there. I really really dont want to drop the tranny again...
    Does anyone know if the threads of the bolts holding on the bell housing will show up on the other side, or are they threaded directly into the engine block? For this particular bolt I would have to remove the starter to see. That might enable me to get it out if I could get a grip on the threads coming out the back.
  18. bad andy
    bad andy 1/2 ton status
    Mar 5, 2003
    151
    Charlotte, N.C.
    you might need to have your carb rebuilt, mine ticks when its cold under acceleration
  19. vince13
    vince13 1/2 ton status
    Dec 6, 2001
    105
    Penticton, BC Canada
    if the noise is in sync with the rpm it could be a loose rocker ticking away. do a valve lash adjustment and see if that solves the problem
  20. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Alright I put the truck up on stands and had a buddy apply some gas while I was searching around on the underside.. It turns out its the CV shaft on the rear driveline! The "ticking" when you get closer to its source sounds more like a "knocking". Has anyone had a knocking CV shaft before?
