What is this tool?
Discussion in 'The Garage' started by Pookster, Jan 17, 2007.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    i know its probably in the wrong section, but I was curious as to its general nature.
    I got one of these [​IMG]
    its a metal punch, I know that much- But the one I got has a die already, but its in a 90* shape.
    What does one do with a 90 degree notch?
  2. goldwing2000
    goldwing2000 Guest
    You make 90°+ angles in sheet metal. :D
  3. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    ah ha!
    yeah, I guess it would work for that as well!
    but it looks like it is used for angle iron to make 90% bends!
  4. goldwing2000
    goldwing2000 Guest
    If it's beefy enough to munch through angle, then you can use it for that, too.
    The only limits are your imagination and the strength of the machine. :waytogo:
  5. diesel4me
    Jul 24, 2003
    17,546
    936
    Massachussetts
    Metal punch press?..
    Last time I saw or used one of those was in vocational school!..works much better and faster than a drill press in mild steel...we used to punch out 3/8" holes in 1/4" plate, and keep all the "slugs"..they made excellent ammo for a wrist rocket slingshot!..yours must have been set up to make 90 degree brackets for something??..
    You can use that to make washers too,with the right punches and dies..
    I almost bought a similar thing,an Arbor press,at a machine shop close out sale,for 75 bucks..but it was a tad too small to use on u-joints,and was only rated for 1-1/2 tons,so I passed on it..:crazy:
  6. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    it acutally die in it is for cutting 90 degree notches out. So far online, I have found a few good dies out there including a metal break.
    I got this one from a buddy- it has to be at least 50 years old! but it works in mint condition, and the company, still makes it!
    Supposedly its a 5 ton unit. Scary!
