What is this? Tranny sensor?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by btolenti, Aug 9, 2005.
  1. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    Wondering what this is..... VSS???
    DO some trucks have VSS on the tranny and then a speedo cable on the transfer case? Oh, it's on the passenger side of my 700R4. There is another
    4 pin on the driver side that I assume is the TC Lockup, per the painless manual.
    My truck is an 86 Cali with CCC and all that good stuff.... :rotfl: :rotfl:
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Well that is one of your pressure ports, so that must be a pressure switch. I'm not familiar with the CCC trucks (they were only sold in cali), but the computer must need to know when you are in a certain gear (4th?). There is generally a lockup sensor internally that controls EGR operation, but the CCC truck needs to do something else.
    It is also possible that somebody made some modifications and added that switch. Some people use one to control the TCC so that it locks up whenever you are in 4th gear.
  3. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    So, i am swapping an 87 TBI system into the truck....can I just run without this plugged in? I assume so....as long as I use a VSS adapter to trigger the lockup, right?
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    if i look through manuals here i could find out the details
  5. dyeager535
    26,980
    I'm with Blue85. TCC connector is on the drivers side of the trans.
    If going TBI, don't see why you'd need it.
    VSS isn't solely for lockup, and no, it is always run at the t-case output shaft since system wants to know CORRECT speed whether in 2wd or 4wd. :)
    VSS pre-'90 for the trucks (and most cars) is all cable drive at the speedo head anyways.
  6. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    Thanks guys, I will just disconnect it and not worry about it.
    I am wondering if this is a better place to install my tranny temp guage, rather than the driver side pressure port???
