what is this?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4wood, May 6, 2004.
  1. 4wood
    4wood 1/2 ton status
    Jul 27, 2003
    116
    Atlanta, GA
    I was crawling around under the k5 today, and I noticed a metal plate that doesn't appear to do anything. It's bolted to the frame rail above the exhaust pipe on the driver side directly beneath the driver seat. I can't feel anything above it and it's not touching the t-case or anything and appears to be just a random piece of metal. Anyone have any clue what this is and what-if anything-it does?
  2. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    Exhaust heat shield. Took mine off because it was rattling.
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    My 1986 K5 had two exhaust heat shields on it . One for the converter and the other for the muffler .
    Tom
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Interesting, i have never seen a heat shield bolted to the frame, i have always seen them bolted right to the bottom of the truck shell itself, with spacers of course.
    Try to get a picture of it, curious.
  5. namkrow
    namkrow 1/2 ton status
    Apr 25, 2004
    166
    So Cal
    On my 77, there's a linkage mount for the auto trans shifter somewhere under there. Not sure if it's factory, as so much has been done to this truck.
    If it's sheetmetal, then it's probably a heat shield. If it's thicker than that...some sort of link for the trans is my guess.
    -T
  6. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    On my '87, the cat is right about where you describe the location of this plate. It's a heat shield, to prevent ass-roasting...
  7. 4wood
    Jul 27, 2003
    116
    Atlanta, GA
    Yeah, after looking at it some more, I got pretty convinced it was a heat shield. I'll try to snag a digital pic and post it. Thanks dudes.
