What is this?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87GMC, Mar 16, 2006.
  1. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    Does anyone know what this is? It plugs into the gauge cluster near the speedo cable. It's on my 87 that had TBI.
  2. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
    vss=vehicle speed sensor.
    used for cruise control stuff.
  3. 87GMC
    Nov 5, 2001
    653
    Olathe, KS 66061
    I don't have cruise. So can I just beat it with a hammer and throw it away?:D
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    I think the TBI ECU needs to know vehicle speed. They got if from the speedometer through that little box up until about 1990.
  5. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Used with the TBI as well. DONT destroy it, I will pay you to ship it to me if you want to throw it away...
  6. 87GMC
    Nov 5, 2001
    653
    Olathe, KS 66061
    I was just kidding about destroying it. I'm pulling the TBI out of my truck and there was a wire to this.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If you look closely, you'll see two clear LED-looking parts on it. One lights up and shines into the speedo housing. Inside the speedo is a rotating reflective part that reflects the light back to the 2nd LED-looking part, which is an optical sensor. Each time the sensor "sees" the light, it sends a pulse to the ECM so that it knows how fast the vehicle is moving.
  8. 87GMC
    Nov 5, 2001
    653
    Olathe, KS 66061
    I planning on selling the TBI once I get the wiring out. Would they need this and my gauges to make the system work? How do people convert to TBI without changing the gauges?
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    It would make it somewhat easier for them, if they wanted to mess with swapping out the dash, but there are aftermarket VSS adapters available from places like Jags That Run, Howell, Painless Wiring, etc.
  10. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    Not to hijack but - They got the vehicle speed from the speedo?! What kind of ass-backwards logic was that?! :confused:
  11. dyeager535
    26,982
    191
    The gauges are essentially the same about '82-89, most trucks even if not CCC, TBI, or equipped with cruise that vintage had the speedo setup to hold the optical eye for the VSS. So the gauges should be easy for someone to get if they don't already have them (older trucks start dealing with the mech oil pressure/amp gauge issue) but it certainly would make a TBI package deal more attractive to some people. Just unplug it all if you don't need it, and throw it in...not like you'll be paying shipping. :)
    As to getting the speed from the speedo, is there a better way to do it? Electronic speedometers didn't arrive until 1990 for the trucks, and they probably could have run something at the t-case like the aftermarket stuff, but that's an additional component/potential leak point, and 3ft of wiring vs 10ft (guesstimate) is more cost effective.
