what is this?
Discussion in 'The Garage' started by slackjawsk5, Apr 1, 2006.
  1. slackjawsk5
    slackjawsk5 Registered Member
    Jan 29, 2006
    38
    berlin,wisconsin
    is this a seal of some sort on the rear driver side of the transmission (notice arrow) not sure if maybe thats where im leaking :(
    thanks chris
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    JB weld?
  3. slackjawsk5
    Jan 29, 2006
    38
    berlin,wisconsin
    not the jb weld....the round plug looking thing
  4. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    speedo hole for a 2x4 version of that tranny. just a freeze plug .
  5. slackjawsk5
    Jan 29, 2006
    38
    berlin,wisconsin
    how is the plug installled? and if thats where im leaking tranny fluid what kind of performance problems would that give me and is that plug easily fixed?:bow: :bow: :bow:
  6. sweetk30
    Nov 1, 2004
    25,537
    536
    just pop it out and replace it. it is just a dummy plug to block off the spot. performance is lost when fluid is low and tranny slips.
    take punch and spin it in the case . then grab it with plyers and pull out. then clean up area good. get new plug and aply some permatex tach and seal to the sides . ( red thin super sticky stiff in white bottle. ) then use big socket that just fits in plug center and tap it in with a hammer using the socket as a driver.
  7. slackjawsk5
    Jan 29, 2006
    38
    berlin,wisconsin
    hey thanks sweet
    i ll try that. would that affect anything else by leaking like vaccums :confused:
  8. sweetk30
    Nov 1, 2004
    25,537
    536
    na just fluid sits in that area.
  9. slackjawsk5
    Jan 29, 2006
    38
    berlin,wisconsin
    you dont think its possibly cracked in that area do you . i was looking around at some other posts and someone was saying that the np203 is heavy and if it was offroaded hard it could of cracked. so the guy before me could of threw some jb weld on the crack and let it be
    hopefully just the plug though
  10. sweetk30
    Nov 1, 2004
    25,537
    536
    best clean it all off with brake cleaner and scrape off the other crap and check over for leaks. if cracked remove tranny drain it clean it good and have it tig welded by a good welder that knows aluminum if its a simple crack. if real bad find a new case.
  11. slackjawsk5
    Jan 29, 2006
    38
    berlin,wisconsin
    thanks again sweet
  12. sweetk30
    Nov 1, 2004
    25,537
    536
    also just incase you dont know thats a th400 tranny.
  13. slackjawsk5
    Jan 29, 2006
    38
    berlin,wisconsin
    yup knew that already just a little confused about the jb weld
  14. sweetk30
    Nov 1, 2004
    25,537
    536
    p.s. little note . welders HATE JB WELD PAIN IN THE ARS TO WELD ON. so if need to weld it remove all of it and thay will thank you for it.
  15. slackjawsk5
    Jan 29, 2006
    38
    berlin,wisconsin
    cool ill start on that tomorrow
