What is up w/ my D44 shafts??????
Discussion in 'The Garage' started by Poohbair, May 16, 2003.
  1. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Ok, so the frontend in my truck came out of a 74 K20. I have a spare set of shafts out of a 73 K20. Found out tonight that one of my ujoints was shot in the drivers side, so White-Rhyno took my front axle apart. Well, the shaft that came out was WAY skinnier than the spare 73 shaft. We figured, cool, bigger shaft... put it in, and it won't turn???
    What is up w/ this??? I thought that a D44 shaft was a D44 shaft???
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Where is the shaft larger at? Where it goe's through the seal? Is just the l.h. side up off the floor?
  3. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    i was always under the influence that they were all the same. You should see the size differnce in the axles. The stub shafts looked identical. I cant figure out the problem either.
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Dumb question, but doe's this have a Locker, welded, or something?
  5. white-rhyno
    Jan 27, 2002
    942
    na, its open. Turns fine util you tighten down the spindle. So its binding behind the spindle. There was a spacer in there, i took it out, did nothing. Though about pulling the seal out of there too but i dont think thats it. Nobody else has had this problem?
  6. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    69 to 72 where the first gens and they had diffrent d44 axles.. I beleave it carried over to some 73.. They where the smaller axles.. So yes there was a diffrence..
  7. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    You could take the spindle out of the 74 and put it in the 73 and that should work..
  8. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Mike would probably be kinda pissed if I did that, since the 73 spindles are on his K5!!
    Has anyone else had trouble swapping D44 shafts????
  9. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    There was "first gen" and "seccond gen" D44 axles, the first gens have smaller axles, u-joints IIRC, bearings and maybe even brakes. Change occured in the early 70's, I know thatK30guy knows the specifics, if he happens to see this.
  10. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Ryan B. just went through this, he had to change just about everything from the knuckles out except for the brake caliper bracket.</font>
  11. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    So wouldn't it stand to reason that if first gens were small and 2nd gens were big, that if the 73 had big axles that the 74 should too? Because it is the other way around...? Crap.
    Maybe that 74 didn't have the stock front end in it???
