What is up with my trannys
Discussion in 'The Garage' started by protechk5, Aug 18, 2005.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    Ok I bought a used 700r4, and right when i put it in it never shifted right. It would always shifts really late, you would have to get on it real hard, close the redline. Now i just got another one, put it in, and it drove perfect for about 5 miles and then after i floored it a little, it started to do the same thing. I dont think its the tv cable cuz no matter how I adjust it, it hardly makes a differenece. What is going on here? Someone said it could be the govnor, if so how hard it that to replace? Anyother things. Also it has a brand new TC.
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    how are you adjusting your TV? sounds exactly like what it is. and the trans you just put in, is probably now toast too.
  3. protechk5
    Sep 26, 2004
    2,015
    VA
    im pertty sure that i had it right, i read it over like a 100 times. If went from perfect to not shifting up without getting on it with in 1 second. Would a stripped govenor gear cause this?
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    no a stripped governor would cause it not to shift at all. almost sounds like you had the cable too tight. how was the pedal effort?
  5. protechk5
    Sep 26, 2004
    2,015
    VA
    it might of could have been a little tight, i guess tomorrow i will take it in to get someone to adjust it right
  6. Big89Burban
    Big89Burban 1/2 ton status
    Jul 19, 2005
    143
    Magnolia, Tx
    Has to be that T.V. cable. The 700r4 uses a governor to shift gears for you. It works like the mechanical advance in a dist. using diff. spring pressures to change gears at different times. The only problem is that the fluid press. from the governor must overcome the T.V. press. to shift. When the throttle is pressed slightly the governor can overcome the pressure easily, but when it is mashed it must wait for vehicle speed to get up before it can overcome the t.v. pressure.
    Try unhooking the t.v cable all together and see if it shifts way too early. If it does then you know there is an adjustment issue. BUT DONT LEAVE IT LIKE THAT AND DRIVE AROUND $0.02
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    chances are its already screwed. they dont like to be driven long with the cable out of adjustment.
  8. protechk5
    Sep 26, 2004
    2,015
    VA
    ha i swear it better not, i only drove it around 5 miles or so, i got AAA should i just get it towed there?
