what is wrong with my trans or transfer case??
Discussion in 'The Garage' started by 89Burben, Sep 10, 2006.
  1. 89Burben
    89Burben Registered Member
    Jan 3, 2005
    98
    CT
    its a th400 and np208
    when tranny is in neutral i cant get my transfer case into 4 lo with out it grinding. so i have to shut the truck off to jam it in.
    Also when in 4 lo to go back into neutral or 4 hi or 2 hi it also grinds when in neutral, and if i slam it into neutral on the transfer case, and i try to go to put it into park the park key grinds.........wtf?????
    is the tranny still spinning the output shaft?
  2. TheSunDanceKid
    TheSunDanceKid Registered Member
    Jul 22, 2006
    60
    arizona, gilbert
    i dunno my 89 blazer does that to
  3. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    mine does that, its normal the centrifigl (sp) force is still spinnning the spinning thingys lol if you wait a sec it *should* stop. a little grinding is normal, youll get used to it.
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,068
    479
    Grand Rapids area
    This is somewhat normal, even if undesireable. If you can get it to shift with the tranny in park, that will prevent everything from spinning, but you may have to find the *right* flat location to make it work.
    The problem is that in neutral, the slight drag in the clutches (even though they are not engaged) is enough to make the output shaft spin.
    Otherwise, you will just have to turn the engine off (or swap in a manual transmission :-) )
  5. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    Had the same issue, just with a 203. After adjusting the linkage, no more grinding. I have never had a 208 and know nothing about them, but might be worth checking out.
