What is your actual size?
Discussion in 'The Garage' started by Chevy305, Jul 7, 2006.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    I run 35in BFG All Terrains and I measured them today to find out that they are not really 35in tall. The front is 33in and the back is 33.5in. All my tires are fully inflated at about 35psi.
    I've heard that BFG runs a little small. So just curious what your tires say and what their actual height is.
  2. MEGALADON
    MEGALADON 1/2 ton status
    Feb 4, 2005
    214
    HOUSTON
    I know I checked my 33 12 1/2 and they came out to 31" tall :rolleyes:
  3. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    How wide are your rims? My BFGs were 34.7" tall with 32 PSI on a 15x8 when new. They were about an inch shorter when I swapped to a 15x10.
  4. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    ...and I've got a set of off brand 33s that are just over 31" on a 15x7.
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I have 37X12.5 on a 15X8 and the most worn one which has about 3/8" tread is right at 36.5" tall. I have not measured a new one but I would venture with 19/32 tread it would be right at 37 or close to it. I also run 25# pressure.
    Ira
  6. pin_it_to_win_it
    pin_it_to_win_it Registered Member
    Jun 21, 2006
    94
    centeral coast california
    i have 35x12.50/15 BFG mudders on 15x12 rims and they are about 33.5" tall with 26#of pressure and about 45% tred left.
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Loaded height of my 39.5" TSL's is 38.5" with 23 lbs of air. They're about 40% tread left.
    Circumference of the tire is 123.5", so my true diameter is 39.3"...and the amount the contact patch squishes is about 3/4".
    Rene
  8. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    I have 15x10 rims and the with 35x12.5 R15
    I didn't realize rim width made a difference in height. :cool1:
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    my old 35 bfg at ko's were 33.5" also. my 42" tsl's with 10% tread at 10psi (2 dont hold air well) measure to 39"
  10. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I've posted this picture before, but the 395/85R20 XMLs are 46 1/2" true height brand new mounted on 20x9 wheels. The 44 Boggers are 42 1/2" tall true height (with a little wear on them) mounted on 15x11 wheels at 16 psi.
  11. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    my 44 tsl's are very close to an actual 44. Mounted on a 12" beadlocked rim. True width is approx. 13".
  12. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I don't know what the other manufacturers publish, but BFG posts the specs for each of their tires. They spell-out the rim size used to get the height measurement, AT FULL PRESSURE. My "E" load rated tires are measured at 80psi. For DD, everything will be less.:D
  13. wicked87_k5
    wicked87_k5 1/2 ton status
    Aug 9, 2004
    235
    Little Falls,NJ... North
    my 33/12.5/15 TSL's on a 15x10 measured out to 34.2 when they were new.
    and my 2 year old 36/12.5/15 TSL/SX's on a 15x10 measure out to 36" and they are 75% tread left
  14. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    38/12.50 tsl's on 16.5/9.75 rims measured 37.5" tall
  15. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    my 40" hawgs on 16.5x9.75" rims are 39" however I have them on 16.5x12 and they are 38.8" measured by the inspection station and passed as I needed 38's!!!!
