What is your opinon on this!!
Discussion in 'OffRoad Design' started by blazen91, Feb 11, 2001.
  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I was talking to a guy today, he said to get a 4" lift out back, I should use the ORD 2.5" shackle flip with custom made longer shackles. By doing this it gives more room for the spring to compress and should give a softer ride. What do you think?
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
  2. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    I don't know if I would go to a shackle a full 3" longer than the stock one. A 1.5 to 2" longer shackle would be more along the lines of what you need. You really only need a long shackle with a spring that has a lot of static arch to it. Past that it helps, but not a lot. You could use a longer shackle with the 4" to get rid of some sag. I'm not a fan of longer shackles since they increase leverage on the bushings and give more side play. But within reason they can work pretty well.
    Making the world better, one truck at a time.
    SW-ORD
  3. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Thanks!
    Not FROM the people
