What is your U-joint angle?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blue85, Feb 11, 2004.
  1. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    Just checkin in to see what are the biggest angles people are able to make work without vibrations.
    I have 15* now and am having trouble getting rid of vibs. The angles are matched dead-on according to my angle finder. It is smooth under launch and vibrates all the time under cruise, except when coasting. This could mean that the pinion needs to come up a little bit.
    There is about 5" of lift in the back, with stock driveshaft (208 slip-yoke) and 14Bsf.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    In all honesty, I don't know or care my pinion angle, and I'd change my u joints once a month if I had to in order to continue to enjoy my truck.
  3. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    I paid $175 for a Cadilliac turbo 400 slipyoke CV shaft. It is well worth it ! Check your local driveshaft guy for details.
    Blake
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Blake
    It was worth it to you, only because it hasn't destroyed the output shaft on your transfer case or that slip yoke yet.
    The Cadilac CV is a very poor idea in my opinion. I don't have a slip yoke, but if I did, I woudldn't even consider putting that on my truck.
    Jess from high angle has a slip yoke CV with splines that run all the way to the end of the yoke, unlike the cadilac CV.
  5. Blue85
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    Yes, it is available. I think I was quoted $475, which is why I'm still trying to make the standard style driveshaft work.
    I don't see why a person couldn't get a Cadillac driveshaft from a junkyard and put on a new slip yoke, like the ones on the bottom of this page: slip yokes: $70-$80 . Maybe there's a reason why it wouldn't work, but I'm thinking you could have the whole thing done for half the cost of a new shaft from high angle.
  6. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I have a CV style rear shaft!
    Bill
  7. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I don't think you're going to be getting rid of the vibration.
    I've been trying to find a solution to my own driveline vibrations. $395 for a High Angle Driveline shaft isn't a viable solution. I don't understand why I can get a SYE and CV shaft for $440 for a fscking NP231 in a Jeep but yet...
    I guess the market dictates such.
    Anyway, the hard part is finding a 1310 slip yoke that is CV-able. Spicer doesn't make a 32 spline one to my knowledge. At least I haven't found one yet. I've been trying to find a slip yoke that takes a Spicer-style driveshaft (strap-type or U-bolt type) instead of what we've got. They're out there but they're $80-$125 depending on where you shop at and whether they're coated.
    The ball end of the CV to hook to the slip yoke is about $40. The ball stud tube yoke is about $40. The H-yoke is about $30. The tube weld yoke is about $40.
    I had all the parts speced out for a 1310 3"x.120" shaft but for some reason it's corrupted on my website and I don't have the information anymore.
    My goal is to build a shaft for $225 or less (excluding tube). I mean, for Pete's sake you don't even have to put a slip spline in a slip yoke shaft so the cost goes down right there. If I can get one for my Dad's fscking Jeep I should be able to get one for my truck.
  8. Blue85
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    Yes, I am unable to fix it with the simple 2-U-joint type of shaft with having my T-case lowered. I was trying to get it back up, but it was driving my U-joint angles to 15 or 16+ degrees. When braking hard, the thing was nearly binding and rattling something crazy. With my T-case spaced down nearly 1.5", I am able to get both angles just under 13 degrees (using 6.5 degrees of shim wedge due to my shackle flip). This runs almost perfect, except for a slight shimmy in 1st gear. The irony is that this is exactly the setup I started with a week ago. I still suspect that the shimmy is due to play in the slip splines and movement of the driveline on the crossmember mount. I can drive 85 and it's smooth (but I usually don't due to the $$)
