what is "zero rate"?
Discussion in 'The Garage' started by francis, Dec 2, 2005.
  1. francis
    francis Registered Member
    Oct 11, 2005
    79
    kemp, texas
    what is zero rateing :confused: it sound like everyone means moving the axle foward. but how is it done and why is it called "zero rate"
  2. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    http://www.offroaddesign.com/catalog/Zero Rates.htm
    Adds lift and *can* (but doesn't have to) relocate axle.
    -- A
  3. K30Blazer
    K30Blazer 1/2 ton status Premium Member
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    can you use these if you already have blocks in the rear?
  4. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    that falls under the no stacking of blocks rule. not good idea.
  5. K30Blazer
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    that is what I thought. Thanks!
  6. francis
    Oct 11, 2005
    79
    kemp, texas
    thanks
    thanks that link helped out alot
  7. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    It is called a zero rate for this reason. Since the zero rate is bolted to the spring pack with the centering pin it is technically considered a spring and can legally be used in a front axle. But since it has no spring rate to the springpack it's called a "zero rate spring".
  8. jaros44
    jaros44 1/2 ton status
    Jul 12, 2005
    408
    Outside Phila. Pa.
    Zero rate
    Thanks good explanation, even an id10t like me got that one!!!!
