What is..
Discussion in 'The Garage' started by Confedneck, Jan 14, 2004.
  1. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    a D60 housing from a 2003 F-Super Duty worth?? i know it would be some work, and would have to be "hi-pinion".. but i have the opoortunity to get one.. and i may take it.. if anything, resell it reasonably to a member if its worth anything.. /forums/images/graemlins/ears.gif
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I think it's a D50, not a 60. /forums/images/graemlins/thinking.gif
  3. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Are the 03's ball joint or king pin /forums/images/graemlins/confused.gif
  4. Confedneck
    Nov 1, 2002
    5,236
    ahh.. but ford did away with the 50 in 99 or 00... but i plan to run numbers and make sure before i buy it..
    im pretty sure its balljoints.. ill have to look tomorrow..
    one of the front end guys seemed to think the short side tube was bent.. its FREAKIN less than an inch long.. its not bent.. all is straight.. so.. any interest still?
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ]I beg to differ...
  6. Confedneck
    Nov 1, 2002
    5,236
    how about.. they did away with the 50 in one tons.. is what im pretty sure it was..
    its a dana 60, originally 3.73 geared
    comes with bearing caps and bolts
    balljoints not kingpins..
    ill be bringing it home next week.. so if anyones interested.. someone tell me what a reasonable price is for the bare housing with caps and bolts.. /forums/images/graemlins/truck.gif
  7. Confedneck
    Nov 1, 2002
    5,236
    ttt... anyone think this would work as an High pinion setup in a chevrolet??
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    dana 50 ?
    did not know such existed,
    how much different from a 60 does a 50 look ?
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You're wrong. All 01 I believe, could be 02 and newer Superduties have a D60 front. Prior to that, the DRW rigs had '60s, while the 3/4 ton AND 1 ton SRW trucks got the D50
    dana 50 ?
    A 50 and a 60 look the same. A 50 is basically a 60 housing, with D44 gears in the pumpkin and D44 shafts. So, basically, it's a D44 on the inside, and D60 on the outside.
    All of these rigs still run the pathetic hub bearing style outers up front too so big tires and that don't go well together without the conversion which is big $$$.
    My guess is that you could get close to $3000 for a front axle from a truck that new.
  10. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    dont know off the top of my head but I have heard that the outers are interchangeable
    Later
  11. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i'll check mine tommorow,see if if there are any # to check. 50 or 60. sterling makes them. to dark and freezing rain right now. /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  12. boggerless
    May 26, 2003
    22,728
    96
    where are you getting it ?word dog /forums/images/graemlins/rotfl.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  13. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Hmmm I was under the impression that all the superduties had front 50's...seemed like something dumb enough for ford to do. /forums/images/graemlins/rotfl.gif
  14. Confedneck
    Nov 1, 2002
    5,236
    check the number on the yellow and white sticker on the long side axle tube.. there will be a "229" or "248"
    229 is d50, 248 is d60, this is a d60.. its a housing only with bearing caps.. no knuckles, not even a cover.. im getting it from somewhere... heh, i do work at a ford dealer ya know.. hey its scrap... what can i say?? /forums/images/graemlins/thumb.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
    that number is in the lower rh corner of the sticker..
