What kind/brand of Spark Plugs do you use?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87K54WD, Apr 3, 2000.
  1. 87K54WD
    87K54WD 1/2 ton status
    Mar 23, 2000
    105
    Texas
    Hey guys,
    Just wanted to see what brand and kind of spark plugs you use. I'm trying to find out if AC Delco makes the RapidFire for the 87 K5. What about the Champion Truck Plug ... anyone heard anything about them? Looking to replace the plugs this week.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I have been runnig Bosh Platnums the last couple yrs. I have no complaints.
    Rock ON![​IMG] 72 K5 [​IMG]
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I've had better luck with Champions than most others.
    '73 K5
    Chevy good...Ford bad
  4. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I run the Champion Truck plugs in mine, I had the first set for @ 1.5 years, and when I pulled them they looked practically new, the only reason I changed them is because I broke 4 getting them out, antisieze is your friend, I've been very happy with them.
    RaisedK5
    "Friends don't let friends drive Fords"
  5. 88Jimmy
    88Jimmy 1/2 ton status
    100
    Las vegas, NV
    Champion Truck Plug Works best in my Jimmy
  6. 87K54WD
    Mar 23, 2000
    105
    Texas
    Looks like the Champion Truck Plugs are leading .... keep them coming! I've seen the Champion Truck Plugs somewhere but what store has them for sure??? PepGirls, Hi/Lo (O'Reily), AutoZone, etc.???
    Thanks to those who have replied so far!!!!!!
  7. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I had AC/Delco in my '74 with stock points ignition. They would foul in less than 200 miles. Yes, the engine burns lots of oil.....only 146,000 miles! My point is I changed to an HEI and Bosch Platinum 8 months ago, and not one fouled plug. HEI or plugs, I'm not sure but I'm keepin' 'em both![​IMG]
    Michael [​IMG] http://jmartin.net/parker/goose.htm
  8. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    I just got a set of Bosch Supers at auto zone for $.99 each. The champions that I took out looked fine, but my mileage went from 13.3 to 14.5 on my next fill-up. Time will tell.
    John
    So Much to do, So LITTLE cash.
  9. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    running some split fires in mine. Seem to work great. Alot better than my AC delco's
  10. 88Jimmy
    100
    Las vegas, NV
    I got my Champion Truck Plugs @ PepGirls
  11. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    I've ran Split-Fires, NGK 4 electrode, Bosch Platinum, Accel, Delco Rapid-Fire and am currently running the Bosch Platinum +4 plugs. They all have done pretty well, and I couldn't tell a whole lot of difference between any of them. I'll probably go back to the NGK 4 electrodes if I ever change them again, I like the design and they last quite a long time for non-platinum plugs. I suggest that you use price and availability as your guide if you're trying to decide between any of these.
  12. BillR
    BillR 1/2 ton status
    Mar 15, 2000
    164
    Flagstaff, AZ
    I use the Bosch Platinum in mine. They seem to work great. The starter barely has to turn!
    Blazin' in Flagstaff
  13. hpfire7227
    hpfire7227 Registered Member
    Mar 14, 2000
    75
    Holland Patent, NY
    I've always ran good ol' AC plugs in all my Chev's. 74 GMC 3/4 ton, 73 pick up w/ .30 over 350, and now my 89 K5. Never ever any problems. I did run Bosch platinums in my...dare I say it...CJ-7, they were excellent also. I think it really comes down to personal preference. Good luck.
    10 BOLTS O' FUN
  14. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    Wow, looks like Bosch Platinums are winning the poll.
  15. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    I run Champion Trucks on my 454. The larger ground and electrode seems to eliminate any ping. I've also tried most platinums, and many others but the Champion Truck plugs seems to do the best. Another good plug if you can get it is the old commercial style AC plug (not rapid fire). The # of this plug is CR-42TS. The commercial is designated by a "C", the R stands for resister, the 42 is the heat range, and TS is tapered seat (for cast iron heads). The commercial plug is a requirement for the Syclone/Typhoon trucks which have a 4.3 Turbo which many of these owners swear by.
    Shawn
    <font color=blue>87 K5</font color=blue>
    <font color=red>454, 6", D60, 14 blt, 465, 205</font color=red>
    www.off-road.com
  16. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    AC Delco. In all seriousness guys, do you really think the high dollar plugs really make a difference in our V8 engines? Sure on a 4 cyl they might, but I have never noticed a difference by changing to platinums or splitfires in a fullsize.
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
