What kind of Battery?
Discussion in 'The Garage' started by cbbr, Jul 31, 2005.
  1. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    The Delco finally died. I'm going, I think to a dual battery setup. Question is what kind/brand of battery to buy. What are you running and why? Is an Optima really that much better?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    In one rig I have a 7-year-old Duralast Gold from Autozone that's still going strong. 3 Die Hards in a row crapped out in 13-15 months before it. :mad:
    A friend had an Optima last 9 years in a rarely driven Land Cruiser.
  3. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I am running a Duralast Gold (800 Cold Cranking apms) that I bought from Autozone for $60. The Sears Die Hard Gold line of batteries are made by the same company that makes the Duralast Gold, but the Duralast's are $20 cheaper...with the same warranty. When I originally bought the my truck it had a red top Optima, which was 7 years old.
  4. 79GMC4x4
    79GMC4x4 Newbie
    Jul 22, 2005
    Northern California
    I can attest to Optima's being okay when treated well. However, they are absolutely no better when somewhat abused by non-use. Had two go bad. The only advantage is when you want to mount them in a position other than straight up. There are a couple of rip-offs of Optimas, which you may find cheaper.
    For now? I just use cheap Walmart batteries. Sounds stupid I bet, but they work fine if the truck doesn't get used enough. For a vehicle that gets used every day, go ahead and spend your money on the Optima, Interstate, Sears Gold......
  5. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I run 1100cca interstate batteries. Never had an issue with them yet.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have a yellow top optima in my blazer and it has always done great for me.
  7. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Been using Interstate batteries for many years, never had a problem...Depending on how many off-road lights,winch,stereo ect... might go deep cycle.
  8. diesel4me
    Jul 24, 2003
    17,537
    922
    Massachussetts
    I'm cheep...
    I pay 15 bucks for a battery at the junkyard I go to a lot--I look for a fresh arrival in a late model wreck--most of them have fairly new batteries in them..opposed to the scrap vehicles hauled in that have a junk one or none..They have a box truck body FULL of batteries all the time--but you have to sift thru them to find one the right size and not too old--I have come away with nearly brand new Die-Hards,Duralast,Ever Starts,etc for 15 bucks!..
    They have a "if it dies we give you another one free" gaurantee for 30 days!--but they wont take the first one back IF its junk!--they consider batteries a neusance,they dont even remove them from the cars most of the time,and they bring sqat at the scrapyard--and they get fined by the EPA if they get caught with a lot of them littering the place--so they just assume sell them cheap,and get rid of them! :D
    I'd like to be rich enough to buy brand new batteries,but since my trucks get used only sparingly now,I cant see paying nearly 100 bucks for one,then having it go dead from sitting...I've had excellent luck with "hardly used" batteries in my trucks..for a lot less than new!.. :crazy: :D
  9. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    If ya go with the dual battery setup, you'll need some kind of isolator system to do it right. My system is composed of Red and Yellow top Optimas, a PowerMaster 140amp alternator and the Hellroaring dual battery isolator/combiner with remote switch. 12k Warn winch, CB, cheap MP3 player. It's a sweet set up. The switch has 3 different positions. 1 for both batteries combined and charging. Truck runs off both batteries. Second position for both batteries isolated from each other and charging, but only running off the main battery. And position #3 completely removes the backup battery from the system. Also, my cables are almost all 2/0 or 1/0 welding cable. The cables from the hellroaring unit to the battery are 2 gauge. Everything else is the welding cable. Battery to frame, battery to block, block to frame, winch to frame, winch to battery, block to body.
    Hellroaring website
    This is what the unit looks like installed in my truck-
    It's not cheap- $179 for the model I got and and extra $40 for the remote switch option. Better safe than sorry though- the electrical system isn't something to skimp on as far as I'm concerned. If ya wanted to know how to do it right, thats one way. :D
  10. blazerpunk
    blazerpunk 1/2 ton status
    Feb 3, 2004
    121
    Trinidad, CO
    Optima red top. The best money I've spent so far. I didn't even notice when I threw my alt. belt, probably 5 starts and 10 min. with lights on still started no prob. when I put a new belt on.
  11. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    Here This is what I asked a optima rep. and this is his answer
    Question:
    I am going to purchase one of your batteries however I'm not sure which one
    would be better for my application. I have a 1982 Chevy k5 Blazer with a
    12K pound winch used for extreme 4X4. Which battery is better, The Red of
    the Yellow top?. What the best battery I can get which will fit my
    application and what is the battery ID# of this battery?
    Answer:
    Since you have a winch, you would need to use a yellow top deep cycle
    battery for your application. Unfortunately, we do not have a battery for
    your application. Although, you can measure the dimensions of your
    existing stock battery versus that of an Optima battery and see if one
    would work for you. Below is the link to our product specs where you can
    find the dimensions of Optima Batteries.
    http://www.optimabatteries.com/publ...ical_specs.html
    I dont know if this helps but I just posted it anyways
  12. justwhatido
    justwhatido 1/2 ton status
    Apr 8, 2004
    1,037
    Mobile, AL
    Dual Optima Marine Batteries
    I want the screw top terminals and DEEEEEEEEEP draw.
  13. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Hey Joe, if you want to do it right make sure you get a grommet on that hole in the firewall or you're asking for an electrical fire. :deal:
  14. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I have only bought one battery in my life, an Optima red top. Since then, its been in 3 seperate vehicles, all my daily drivers. Other than that, I just get my batteries from parts trucks for free. $15 for a battery! Are you crazy? I'm too poor for that kind of splurging! :haha:
  15. no1uknow
    no1uknow 1/2 ton status
    Nov 10, 2004
    145
    Southern Cali
    I'm happy with my optima yellow top. My truck sits for long periods of time and when I go to crank it over it never fails.............
  16. blownout
    blownout Registered Member
    Jul 19, 2005
    18
    ont.canada
    just use some .
    use some ones car to jumpe start the truck its cheeper then buying one thike about it
  17. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I know....I didn't have time to find a 2" grommet before Blazer Fest, so I just lined the hole with electrical tape. Got any idea where I could find a grommet for a 2" hole?
  18. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I am using a battery from autozone.... 1000ca (900cca I think) and am going to get a second one......
    question for you people with duals and an isolater... I understand that an isolator will keep them seperate but what if you want to use both?
    my Ramsey Patriot 15k is currently 298 miles from me :doah:
    then when I get it I will be camping at asetique or chinketique (sp?) for the weekend.. so next week I am going to start my dual battery swap and winch install....
    I want to be able to use both batteries for the winch..... so just hook it up like a diesel?
    I dont care about one only used to start the truck.. that is what my battery jump box is for :bow:
  19. cbbr
    Jul 17, 2004
    14,681
    Seem to be more Optima's than any thing else. Are they a problem when you only drive the truck on weekends? I have been told that they need to be charged frequently or they have problems.
  20. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    If you plan on parking it for a while, disconnect the batteries from each other(dual batteries if this is your plan) and from the truck itself. Kind of a PITA but it helps the life of any battery whether it be optima or something else.
