WHAT KIND OF FRONT END DO I HAVE???
Discussion in 'The Garage' started by blublaz57, Jan 27, 2003.
  1. blublaz57
    blublaz57 1/2 ton status
    Feb 2, 2002
    175
    aarizona
    ok blew out my lockrite locker and had no spider gears to replace it ,but i have a d44 w/373s out of a jimmy (79)so i go to get the spider gears,pop the cover wow something i never seen before ,i removed the shaft tht holds everything together and had to remove a spring tensioner that kept pressure on the axle gears ,then i puul the little gears out (no problem)then i go to pull the axle gears out and they have pressure plates on them that fit into a little groove kinda like clutches. maybe could it be a limited slip or what i dont know thanks Don
  2. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    It is definately a 12 bolt.
  3. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    they never made a 12 bolt front end. It say its a dana 44 with a gov lock in the front axle. some truck had that insted of open diff..
  4. blublaz57
    Feb 2, 2002
    175
    aarizona
    right it is a 10 bolt . so is a gov lock better than a open diff?ive only heard bad things about them .could someone tell me just how a gov lock works????thanks Don
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    sure. you step on the gas hard and it explodes into millions of tinny pieces. gov-locks suck royally. I blew mine apart in the rear on the street with 32" tires. There are some sweet pics of destroyed 10 bolts with the govlock to blame. I saw one yesterday that was awesome.
    Govlocks are supposed to work like a l/s and lock up if they sense enough wheel spin or somthing. They don't work half the time from what I hear and then the other half it seems like they are destroying themselves.
  6. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    gov bomb + big tires + Horse power = /forums/images/graemlins/shocked.gifBOOM!, scraged gov lock /forums/images/graemlins/angryfire.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    gov-lock + stock 350 + 32's = boom .... You don't even need big tires or high HP's.
  8. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Do you actually think I was serious? /forums/images/graemlins/rolleyes.gif
  9. ben427
    Mar 10, 2002
    1,123
    Well, you sounded it, its hard to tell sarcas on the net! /forums/images/graemlins/thumb.gif
  10. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Most should have gotten it with as many of the 12B front threads that have been on here. Then again, someone had to make all those posts. A /forums/images/graemlins/tongue.gif would have helped.
  11. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Hell, I'm never serious about anything. /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif
  12. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I've seen this monster in Don's truck and unless the front GovLok is different from the rear Govlok, it's not a Govlok. There is no cam that flips or even resembles a GovLok. The side gears are splined on the outside and have clutch packs. There is a large S spring in the middle that the pin goes throush. I'm thinking like an old Eaton, maybe?
  13. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    That is an Eaton limited slip, or Posi. They were optional in some years in front Dana 44s on GM trucks.
