What kind of gear lube should I use?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, Apr 12, 2000.
  1. '73 K5
    '73 K5 1/2 ton status
    I'm getting all my gears, axles and stuff installed tomorrow. Finally.
    I'm putting an Eaton limited slip in the rearend and was wondering what kind of gear lube y'all are using. I know I need one that has an LSD additive, but what brands? Also, should I get a synthetic or just a regular one.
    One more thing. The Eaton website said that if you use a synthetic gear lube, that you should NOT use an RTV sealant to put the diff. cover back on. OK, fine, but what else is there. I thought all those sealants were about the same as RTV. What else is there besides just the thin crappy gasket?
    '73 K5
    Chevy good...Ford bad
