What kind of jack is need?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by trogdor4x4, Feb 23, 2004.
  1. trogdor4x4
    trogdor4x4 Registered Member
    Dec 15, 2003
    37
    Spring, TX
    the stock jack for my truck is too short, all I have on my truck is 33s with stock suspension. What jack is usually used or is good for my application?
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i like to carry around a little 2.5 ton floor jack. works great for lift by the axle tube.
  3. mr_fujisawa
    mr_fujisawa 1/2 ton status
    Sep 1, 2003
    288
    SF CA
    try a hi-lift jack . they are pretty good and not too expensive
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You should only use a hi-lift off-road only...they're very unstable, but you need one though. As for on the road, a little floor jack like Russell said is best or you could get a bottle jack...
  5. dyeager535
    26,976
    My stock jack works fine on 33's, lift on the axle tubes. It takes awhile, but I like having it underhood and out of the way of everything else. As often as I use it, it really doesn't matter how slow it is.
    Perhaps you have a 2WD one...although they may go higher. 2WD jacks have a "J" hook instead of the "U" (very shallow U) that the 4wd ones have.
  6. trogdor4x4
    Dec 15, 2003
    37
    Spring, TX
    Thanks for the posts, I will try again the stock jack (my truck is 4wd). If it doesn't work, I think I will go with an adjustable bottle jack.
    Any other suggestions?
  7. dyeager535
    26,976
    Are you sure it's extending fully? I know when I got mine it was rusty from sitting outside, and it took a bit of oil on it, and moving it up and down before the operation smoothed out.
    Before I started on it, it only extended about half as far as it should. IIRC, it "telescopes" TWICE before it's at full extension.
  8. trogdor4x4
    Dec 15, 2003
    37
    Spring, TX
    I had to play with it a little and then it telescoped to twice the hieght.
  9. dyeager535
    26,976
    So was that the problem or even at twice the height it still doesn't work?
    Hope I nailed this one for you though! /forums/images/graemlins/smile.gif
  10. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    was the jack under the hood still??
    I know up in the salt states where i am, the dirt gets into it and binds the jack. I keep mine in the truck now! But it works with the 33's.
  11. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    if the jack is too short, or you need it up higher, can you put a cinderblock under the jack? or would some dense wood work?
  12. dyeager535
    26,976
    Lets not geet into cinderblocks. Not really a good idea to be placing 1250 pounds (or so) on one. /forums/images/graemlins/smile.gif
    Block of wood will be ok, I'm sure there are plenty of us on here that have used a nice square block of dense wood to get some extra jack height. Just don't trust it to climb underneath without other support like jackstands.
  13. tecton
    Dec 1, 2002
    1,553
    WV
    lol
    ok i was just wondering
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've used wood before, no issues. Picked up an awesome beefy set of 6 ton jackstands at menards for $18 for once it's in the air!!
  15. potato76
    potato76 1/2 ton status
    Mar 21, 2002
    922
    phoenix, AZ
    when i got my truck i went and bought a 3 ton craftsman floor jack and jackstands for a hondo($100 for the non slang folk)does me well.Kind of huge and annoying to get in and out of the truck but does the job. /forums/images/graemlins/peace.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/shame.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/hack.gifok excessive iconing
