what kind of mods are needed for axle swap?
Discussion in 'The Garage' started by bryguy00b, Aug 27, 2002.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    are there any mods that need to be done to swap in 3/4 or 1 ton axls?
    Bryan
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    1/2 to 3/4 rear (14 bolt) is a direct bolt in, minus the u-joint difference, poss driveshaft length change, E-brake cable mod...but other than that is cake.
    The front if converting to 8 lug....but still 1/2 ton is easy and fairly cheap. Goning to a DANA60 front is fairly easy too, but not easy on the wallet!!! /forums/images/icons/frown.gif /forums/images/icons/wink.gif
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok thanx...
  4. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    wait so what about drive shafts do you need one ton drive shafts or something ...?
    Bryan
  5. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    no u don't. ya just need that trick u-joint to fit the 14ff to the half ton driveshaft. there is a write up on axle swaps and it gives some tips on the 14ff. axle swap well i hope this helps.
  6. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    if you need a napa pn lemmie know for u joint, i got it somewhere.. if you go to 1 ton, you will need to move each perch in 1 inch, stock 1/2 ton perches are 42 1/2 apart center to center of perch. 1 ton is 40 1/2. thats how youll know the difference. on 3/4 most brake cable are same though and bolt in.
  7. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok thanx a lot guys!!!
    Bryan
  8. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i just needed to move the rear perches. the fronts bolted up
    th new rear u-joint for me was a 348
    the front shaft was the same. if you need a new joint look for Yunit...he was trying to get rid of some cheap
    ryan
