what kind of oil for the rear end.
Discussion in 'The Garage' started by adamforsythe, Sep 10, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    I have a small leak in the gasket where my diff cover goes. I want to replace that today. What kind of oil should I use?
    Plus I want to see what kind of shape my rear end is in.
    Adam
  2. Igorr
    Igorr Registered Member
    Aug 27, 2005
    21
    Bend, Oregon
    Adam,
    I use sythetic gear lube in mine. I have use sythetic's since I spent a couple of years road racing sports cars, a few years back. I first used it in the constant velocity joints on the racecar, many folks were having problems tearing them up. I never in the two years experienced a lubricant related failure. Now missing a shift and over reving the thing (gianed a few extra engine pieces), getting up close and personal to the armco barrier (a few extra body and suspension pieces) I could not blame on lubricants. Except possibly I missed shifts more often in before changing the gearbox over to synthetic lube, it shifted much smoother and faster with the slippery, and granted expensive stuf. Also, if memory servs you will not find a gasket on the differential cover, I believe it is a layer of sealant.
    BTW - my birthday is Sept 18 as well!
    Les
  3. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,021
    849
    Pinckney, MI
    If you have a LS or some form of locker that requires it you should use Synthetic if not just good ole 80-90w
  4. Guss
    Guss Registered Member
    Feb 6, 2005
    78
    houston
    just rebuilt mine and only put 80-90w in it and i beat the heck out of it its fine.
  5. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Sweet, I will check it out. I want to get all of the leaks taken care of because I am going to be putting rust bullet on my '86 K5 next week as a birthday gift to myself. This will be the very last major project I will do to my truck this year. Next year I will be adding bigger tires, jacking my truck up 6", ETC.
    Adam
  6. Igorr
    Aug 27, 2005
    21
    Bend, Oregon
    Just remembered, if one has a limited slip with clutches like the old detroit locker, l do not think they recommend synthetic, it is too slick and the clutches will slip.
  7. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    I think I will just run good old 80-90w.
    Adam
