What kind of PS fluid?
Discussion in 'The Garage' started by CK5, Mar 7, 2002.
  1. CK5
    May 19, 1999
    21,622
    701
    CO
    What is the best Power Steering fluid to use for hydro assist steering? Some kind of low foaming I would imagine.
  2. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    since mine leaks like a sieve currently, the nice cheap Coastal stuff.... after fix the leaking hose, it'll prolly still be coastal. I dunno what one would use in a hydraulic ram assist steering, but I'd immagine anything would work, as long as there was enough of it.
    -Rich
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have always used ATF. So how about some Synthetic ATF?
  4. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    There was an article in Petersons awhile back about a no foam low temp fluid I'll see if I can find it...
  5. Grim-Reaper
    7,385
    Atlanta
    I'm running Valvoline Synthetic Power steering fluid. Got it a Auto zone. I had burned up my fluid and flushed the sytem with this. Seems to doing good so far. Still going to put a cooler on it. Older Fords have a nice compact cooler on the trucks. On them it mounts off the Accessory brackets on the front of the engine.
  6. chevyfumes
    Feb 24, 2000
    38,584
    266
    Huh, I just looked through the last12 issues and couldn't find it I think I took that issue hunting and it got ruined... Seems to me that it was August, September or October issue, maybe even November....
  7. chevyfumes
    Feb 24, 2000
    38,584
    266
    I'm missing august and september and its not in the other ones I just looked sorry.
  8. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Steve, my buddy D (came over when we were doing your steering brace) just did full hydro on his Sami, and used the low foaming fluid, pretty sure he bought it a checker, Pyroil brand, $10 for a gallon jug. Said no problems bleeding it. Of course he told me this right after I bought 6 qts of regular stuff.
    Pete
  9. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,034
    1,083
    Dallas
    Amsoil has good quality expensive stuff.
  10. chevyfumes
    Feb 24, 2000
    38,584
    266
    OK after searching their sucky site I came up with the September issue "Steering solutions for rock crawlers"
  11. CK5
    May 19, 1999
    21,622
    701
    CO
    Thanks guys, my 90 came with a factory PS cooler so I am going to just run that and see how it goes along with the low foam stuff.
  12. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    Any synthetic is a good choice. I've used the valvoline and it was OK. I've even used Hydraulic fluid. But DO NOT use ATF. i'm guilty of useing it too, but since i've started building all these boxes i've found that the boxes that have ATF in them have really dried out O-rings. May just be coinsidece but It's not worth the gamble.
    Now don't keep us in suspence. How does it work? Good, bad, ugly?
  13. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    LOOK I HAVE TRYED A LOT OF DIFF. FLUIDS WITH MY A.G.R. STUFF AND FOUND THAT ROYAL PURPLE IS THE BEST SO FAR. A LOT OF HIGH PERFORMANCE SHOPS ARE STARTING TO USE THIS IN MOTORS ALSO.
  14. CK5
    May 19, 1999
    21,622
    701
    CO
    I plan on installing everything this weekend, I should have everything together by tomorrow, Because of the limited space of my hi-steer setup I have to go with a howe ram to have enough room (smaller), there is no room at all above the axle so it gets mounted below the tierod but above the axle. It will be nice to get rid of the leaky AGR box and slap Matts up in it's place, thank's for all the help so far, here is a pick of the west texas offroad kit, I had to shovel my driveway to take this pick.
    http://coloradok5.com/temp/kit.jpg
