What kind of saw blade?
Discussion in 'The Lounge' started by 84gmcjimmy, Feb 4, 2006.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I meant to post this a long time ago but I keep forgetting. I am building some shelves in the basement with this shelving material we bought from a building supply store. I was just wondering what kind of blade I should use with the circular saw? I have a feeling that if I use a aggressive tooth one it may tear the board apart. So should I use one with more small teeth, or less teeth and large teeth?
    here is a picture of the board to get an idea what I will be cutting:
    Thanks!
  2. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    More teeth for trim materials, less teeth for anything else, more teeth also means more expensive but there is less of a chance to screw up your trim material.
  3. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Looks like it has a melamine top layer. Circular saw blade shouldn't matter much, I've used a wood blade for ply with no problem. But you need to run masking tape along the line you want to cut, on both sides, so the melamine won't chip.
  4. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Use fine tooth and turn it over so the finished side is down, its less likely to chip.
  5. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    I agree with last three posts.
  6. Storm Trooper
    Nov 24, 2000
    4,640
    and cut slowly.
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Thanks guys. The tape sounds like an excellent idea. No need to buy blades my dad has lots, i'm sure one of them will work fine.
  8. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Good for you for buyilding your own
    Why didn't you just go with pine or something similar?
  9. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    This stuff was cheap and it looks good with white walls and white appliances in the basement.
  10. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Cool. All my furnitures, that's been made by me anyway, is pine. All blocky, but sturdy.
    Don't let it get wet.
