what kind of screws are these? holley guys?
Discussion in 'The Garage' started by bryguy00b, Jan 25, 2004.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok im rebiulding a holley 600 carb, and theres the aluminum plate on the throttle body held on with 6 screws, that of which i dont know what kind of heads these are to take them out /forums/images/graemlins/confused.gif this is my first time rebiulding one so im not 100% on what is what...but does any one know what screws these are? i would post a pic but my battery is dead..
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    secondary metering plate uses screws called 'clutch style'
    a small flat screwdriver carefully applied will work
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    hmm ok ill try that.
    then the block with the lean mixutre screws on it must be the metering BLOCK then?? im ganna have to go out and get me a book here pretty quick..
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    yes that is the metering block
    most 600s have the plates in place of a block on the sec side
    the mixture screws you are refering to are just for idle mixture
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i dunno, but this aluminum plate was behind the block on the secondary side. and yea i got it out fine with the flat head...dunno why i didnt think of that /forums/images/graemlins/rotfl.gif
