What kind of spark plugs do you run??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazen_md, Jul 20, 2002.
  1. blazen_md
    blazen_md 1/2 ton status
    Aug 20, 2001
    129
    MD
    I have a 90 k5 with a 350 tbi, do you guys run platinum or standard plugs or does either one show a real difference?? Just want some opinions, thanks.
  2. dyeager535
    26,982
    191
    From now on out, I'm going to be running AC Delco plugs.
    Too many problems with the low end "standard" plugs.
    I know you weren't asking necessarily for the low end stuff, just some advice.
    I have a feeling (speculation) that the "better" plugs only serve to increase plug life with "better" material that won't erode as quickly. Ideally the better the material conducts, the more reliable the ignition, but the fact is, (to simplify) as long as the gap is jumped by the spark, you have ignition. Since HEI puts out so much voltage, its very easy for it to jump the .035/.045 that Chev recommends, regardless of the plug type/material.
  3. rusty79
    rusty79 1/2 ton status
    Jul 22, 2001
    139
    Hampton Va
    im running delco platinums got them at advance for about 1$ a piece working great so far
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    The subject of spark plugs was just talked about. I think it was under the garage forum. Try a search..
  5. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    ac delco
    Later
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Cheap AC Delcos...opened the gap up to about .45 to help gas mileage if theres any truth to that...seemed to help a little
  7. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Stock AC Delco Platnium plugs for Vortec heads.
  8. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Bosch plats.
  9. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    Delco rapid-fires
