What kinda crossover setup is this?
Discussion in 'The Garage' started by mrk5, Aug 24, 2005.
  1. mrk5
    Apr 20, 2004
    12,351
    1,051
    Northern Colorado
    I saw this at the junkyard yesterday. It's a '73 K5 that has had some work done to it for offroad use.
    What kind of crossover setup is this? Would it be worth pulling? I'm suspicious that it is a knuckle from a Jeep D44.
    The front axle has had some work done on it. New spring perches to rotate the axle and add 1-2" of lift. And there are two plates w/holes drilled in a horizontal line welded on top of the axle tube just to the driver's side of the pumpkin. For hydraulic assist? You may be able to see what I'm talking about in the top pic.
    So what do you all think, should I pull that crossover setup off to use for myself?
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Looks homemade.
    looks like you can see a weld bead on top of the stock knuckle right where the tie rod mounts.
    Know that draglink looks pretty beefy so that mught be worth taking. I wouldnt trust that knuckle though. Looks to thin up at the top where the draglink connects.
  3. mrk5
    Apr 20, 2004
    12,351
    1,051
    Northern Colorado
    Good catch, I didn't notice the weld bead. I was thinking about at least getting the draglink.
  4. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    that top bracket might have been for a limiting strap? seems located i a bad place for hydro assist. knuckle sooks scary weak with all of that leaverage on it.
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Did it have the bent draglink??
    Looks like it in the first pic. I would get that for sure.
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    The part that the drag link connects to looks like part of a drop pitman arm for a Ford truck (mounted upside down) ghetto fabbed to the knuckle. If the guy was stupid enough to fab up this kinda crap, I would just let the drag link there too... who knows what he used to make it.
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Looks like a scary homemade setup to me! What's with the goober weld looking stuff right where the draglink connects to the "arm"? It also looks way thin with ton's of leverage on it.
  8. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    That looks like a 60 hub in the background of the second pic. ........
  9. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Thought the same......but then I saw it was 6 lug :doah:
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Wow! You should submit those pics for posting on that "Scary Steering" page! :eek1: What a hack job! :doah:
  11. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Looks like somebody home fabbed an ORU knuckle as seen below:
  12. mrk5
    Apr 20, 2004
    12,351
    1,051
    Northern Colorado
    The drag link was straight.
    I was hoping I'd found one of those junkyard treasures you're so good at finding. :wink1:
    Now see, I was hoping it would be something cool like that, but I totally missed the weld. Now that you guys pointed it out, it is obvious.
  13. captaininsano
    captaininsano 1/2 ton status
    May 4, 2004
    233
    Bay Area, CA
    Anyone have experience with that ORU knuckle? Stout piece?
  14. captaininsano
    May 4, 2004
    233
    Bay Area, CA
    Holy crap! Nevermind I just saw the price! :eek:
    $595.00
