what kinda metal for skid plates...
Discussion in 'The Garage' started by jekbrown, Mar 10, 2003.
  1. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    new tcase is *finally* going in tomorow... once thats done, I'll be ready to set up some skid plates for my rigs underside. What kinda metal do you guys recommend/use? I mean, could I use some thicker aluminum diamond plate? if not..steel? 1/8"? 3/16"? anyone have any pics of their own custom skid plating? I think the only really well done 'platin i have seen pics of here is on SW's Jimmy. /forums/images/graemlins/grin.gif any1 else? /forums/images/graemlins/smile.gif
    j
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I think I'd use either 3/16" plate steel (or diamond tread, whichever.)
    If you're going to make it, make it freaking overkill /forums/images/graemlins/thumb.gif
    -- Mike
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i will be making mine out of aluminum. 3/16ths. but i have to get the doubler and go from there.
    grant
  4. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    I'd use 3/16" AR (abrasive resistant) plate. Checker (or diamond) plate will gall on the rocks and not slide as intended...
    Rene
  5. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Unless you're really banging on the rocks, 1/8 should be okay, unless you have a large gap to cover. Diamond will hang up, it's your call. Aluminum will work, and will save a ton of weight, but it's not nearly as strong and you won't be able to weld it to your x-member, which might make it a bit harder to fab. You might want to check out some of the skidplates that are on the market, and see what they use. I used 1/8, braced with 1 1/2 angle on the front of my old toy, and I could hit anything I wanted with it.
  6. XtrmChevy
    XtrmChevy 1/2 ton status
    Jul 14, 2001
    148
    Finland, Europe
    Is not aluminium too soft for a skidplate? I know it is light and everything but I have seen trucks getting stuck because the aluminium "grabbed" the rock it was supposed to slide over.
  7. bowtiepower00
    May 11, 2000
    924
    AZ
    Yes it is quite a bit softer than steel. If you're going to spend a lot of time on your skids, I'd go with steel. To guard against the occasional scrape, Aluminum should work fine.
  8. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    hmmm... i dunno... think I'll try the 1/8" steel with some angle iron support ribs. What I really need to do is get my welder up and running so I can start fabbing some stuff easier. /forums/images/graemlins/grin.gif thanks for the input guys. Guess I'll save the aluminium (limey-speak version!) for lighter duty work...
    j
  9. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I'd go with 3/16" instead of 1/8". 1/8" bends to easy. I've got the dents in my Knight tranfer box to show for it from broken asphalt being droped in it, and it's 1/8" with crossmembers every 8"s.
  10. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    If you can find it, Core-10 is a good alloy choice. It is what those rock hauling OTR trailer beds are made from. Good abrasion resistance w/o being brittle as some of the other AR type alloys tend to be.
    I'd go with 1/8" (or 10 gauge) in short spans and 3/16" in long spans. 1/4" would be unreasonably heavy for all but the most brutal.
  11. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    hmmmmmm... maybe 3/16" is the way to go...........hhhhhrrrrmmmmm. anyone have any pics? lots of good thoughts... but it'd be cool 2 see some pics too. /forums/images/graemlins/grin.gif
    j
  12. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    aluminum would be good as a engine skid plate, as it is rare to bash that area.
    for a t-case, at least 3/16 and i would suggest 1/4
  13. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    I think SP-50 is even tougher to dent than Core-10. The most I've seen with SP-50 is for it to be rolled, I've never seen it formed. With some bracing behind it you could use 1/8".
    Rene
  14. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    tungsten or magnesium!!!
    cool sparks and possibly flames
  15. bigjbear
    Feb 18, 2000
    13,971
    451
    Marietta GA
    The STOCK skid for the 203 on my '73 is 1/4" so I don't think I'd want 1/8"/10ga there, especialy w/ an alum case(208/241). 3/16" is nice for the fuel tank.
  16. tmaxxer9
    tmaxxer9 1/2 ton status
    Feb 12, 2003
    195
    Minnesota
    i would use titainium
  17. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    i always thought t1 steel would make great skid plate material /forums/images/graemlins/laugh.gif
