what kinda paint to paint engine/ axles with?
Discussion in 'The Garage' started by 89BlazerK5, Aug 16, 2003.
  1. 89BlazerK5
    89BlazerK5 1/2 ton status
    Aug 24, 2002
    134
    i'm gonna paint the engine before i put it back together, and i'm going to go ahead and paint the front axle while its out. the axle is going to be black, but i might paint the block hugger orange, and the intake manifold a silverish peweter color. should i just go to the hardware store and get the high heat spray paint? like rustolieum or something? should i hit it with a clear coat whem i'm done?
    thanks /forums/images/graemlins/k5.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    try the auto parts store..get high temp engine enamel...you'll be set, enamels are HARD
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I'm using two coats of a black, low-gloss engine enamel on my axles (got it at walmart). Pretty tuff as far as I can tell...haven't moved the axles around too much to see if it's really sticking well, but it looks good. Pics are in the link in my sig.
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    just because its a enamel does not mean its hard but you DO want to use a enamel(unless you wanna spend alot of $$$). The other cheap choice you have is a expoxy paint... Rustolem isent that great but its not TO bad either if you can find a BLP Mobile Paints store they make some nice stuff the rust-kill is what you will wanna go with(its good up to 300degrees)
  5. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    hig heat engine enamel will work the best for the engine. A hard enamel on the axles will last the longest but you really need to prep well. You can use polyeurothane paints on your engine. I did in my showcar. Matter infact my block is the same color as the car and it has lasted really well. Arund the header not so much.
