what kinda rings in a mild 454?
Discussion in 'The Garage' started by fortcollinsram, Dec 11, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I need to get some piston rings for my 454 buildup...Sould I go with Plsma Moly or Cast Iron?I know Moly last longer, but I have heard taht they are a b!tch to break in correctly...Any thoughts?
    Chris
  2. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Plasma moly rings break in fine, I have used them on several rebuilds and never had a problem with them sealing quickly. You have to use a different stone on your hone for moly rings. Chrome moly rings take forever to seal. Use the plasma moly rings over regular cast iron rings.
  3. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    On a basic rebuild I would only use standard iron rings. Plasma and moly rings definatly last longer but as they wear they also wear more of the piston bores. Using Plasma and Moly you pretty much guaranteed to have to rebore each rebuild. With iron rings you can sometimes use a block 4 or 5 times before it is junk.
