What kinda work is needed to chop the frame?
Discussion in 'The Garage' started by mudrunner78, Jun 13, 2002.
  1. mudrunner78
    mudrunner78 1/2 ton status
    Sep 7, 2001
    366
    Rocksprings, TX
    Ok I am by far not a engineer, I would like to remove part of my frame behind the rear wheels on my 78 k-10 long bed. I was thinking(thats when bad things happen) that if I remove my bed, chop the frame near the rear shackle flip brakets and add offset zero rates I will gain in the departure angle. I would also like to move my front axle forward and remove the bumper for approach angle. What kind of bracing will be required to brace the back, and how close to the shackle can I cut? I plan on building a flate bed with a fuel cell in a box, and adding a tool chest and some of the many ammo cans I own. Thanks Jesse
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    That would be fairly easy to do. I would add a brace across the back of the frame or reuse the one currently at the back of your frame. Using a flatbed save a lot of body work.
    Kenny Whitman
  3. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I would chop it right next to the bracket.Then use a piece of 2x4 tubing and recess it in the frame.This will be your brace and bumper combined.Add a pair of rectangle flush mounted trailer lights and you are set.You could also add a 2" receiver tube in the middle of the bumper and have a tow point.Brady
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You'll need to replace the rear cross member, but that's about it. No problem, that rear cross member doesn't do much any way, the one I built is much stronger, overkill actually, but it is also part of my rear suspension...
    To see what I've done, look here.
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    If you do the 2x4 retangular tubing for the crossmember cut it out for the oval sealed beam tail lights like they use on big trucks/ boat trailers. They mount in rubber gromets that also act as shock mounts. And being sealed they'll work under water too.
  6. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    i just did this exact same thing...
    look for the naches pictures for the blue chev flatbed witht eh fuel cell on the back...
    just hack away... but keep the brack that holds the rear ogf the frame together...
  7. mudrunner78
    Sep 7, 2001
    366
    Rocksprings, TX
    If I chop right at the shackle mount I will not run into any strength issues? I plan on using Hummvee taillight since I can get them for free, I want to install them flush. Iwonder what type of bumper I need on the back. Thanks Jesse
  8. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    If you want, look at my webshots. My rig is bobbed 13" and I'm running a 20 gal rci alum fuel cell.
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You won't have any frame strength issues as long as you move the rear cross member or build a new one. As for a bumper, it depends on what you want.
  10. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    looks like you have an ongoing extensive project.id like to see the finished pro ject.it sounds pretty crazy /forums/images/icons/cool.gif
  11. mudrunner78
    Sep 7, 2001
    366
    Rocksprings, TX
    yeah the project seems to be alittle bit of a big deal but I belive it will be well worth it. Plus now that I have a welder the flat bed will be easier. Jesse
