what length shackles for 64's?
Discussion in 'The Garage' started by muddybuddy, Jul 9, 2006.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im going to start my 64's swap in the rear on tuesday and need to order some shackles for the flip. the springs are 5" lift if that matters. what length do you all run? thanks
  2. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    none of the 64" spring crew on? my guess is i should go with 6" shackles, but im not sure
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    The rule of thumb for compression shackles that I was given by Erik @ Deaver Spring is this:
    Take the difference btwn the at-rest bushing to bushing straight line length and the bushing to bushing length along the main leaf. That is the minimum shackle length & that length + 2" is about your max length.
    I believe this rule assumes that your bump stop will limit travel with 1" of arch left in the spring, which is what Deaver normally recomends with their springs. Otherwise something like a wanna-be monster truck could end up with some reeeaaallllyyyy long shackles.
  4. Cajun4x4
    Cajun4x4 1/2 ton status
    Oct 17, 2005
    889
    Lafayette, LA
    redneckdude went with 6.5" shackles
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    alright thanks ill measure them
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    well i just measured and the bushing to bushing is 60.5" and the main leaf is 67" so i can use anywhere from a 6.5" to 8.5" correct?
