What lights do you have?
Discussion in 'The Garage' started by 78Suburban, Mar 2, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    It almost seems like I have asked about this before, I dunno. Searching never does much good. I'm thinking a lift will be too expensive to get for my birthday, so I want to ask for some lights and a hi-lift, probably. I would love to see what type of lights yall are using, and year your opinions on them.. I know lights on a roof look tacky to many of you, but I'm thinking I want 4 or so on my roof. Summit has some decent prices on kc knock off's, but I'm just not sure. Having maybe two for long range would be ok, but I'm alot more concerned with driving lights that will throw a super wide beam on the trail, so I can see what's 10 feet in front of me. I definitely need something other than the stock headlights, as I can hadly see at all with them.
    thanks,
    James
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    First thing - are you still running your headlights off of the factory harness, or have you upgraded to this kind of relay setup?
    http://www.73-87.com/7387garage/exterior/headlight_relay.htm
    It's quite cheap to do, and really makes an enormous difference when it comes to getting full voltage to your lights.
  3. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    I have 8 after market lights... and i had my alterantor respooled to about 160 amps. I got the lights off ebay for like 140.
  4. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    I'm gonna need to make a light bar if I do get some
    I would love to see some pictures of light bars (on the roof) yall have made, and maybe some exact deminsions, materails, ect..
    thanks,
    James
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    a few:D
  6. 4xcrazy
    Oct 31, 2003
    9,471
    5
    :D :eek1: :D
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Just 2 6 inch round kc's for now on the DD :D
  8. The Butcher
    The Butcher 1/2 ton status Premium Member
    May 17, 2005
    420
    39
    Texas. In a van, down by the river!
    I put some of the 8" round Pro-Comp lights on the front of my K5 and they are pretty damn bright. Fairly cheap for an 8" also. You can buy a relay, fuse holder, a switch, and some wire from auto-zone and make your own harness. Or just buy one of the pre-made harness that are available.
    I think Eagle lights used to make KC knock-offs as well, so you might see if you can find a 2 light package that comes with the lights and the wiring harness. Makes things easier.
  9. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    So it would be significantly noticable even with the old single style headlight setup? I just may have to look into this..
    Still may try to get a few extra lights, cause I do alot of night wheelin.
    thanks,
    James
  10. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    I just bolted a set of 6" Daylighters to my bumper. Anyone have any suggestions of good, cheap light bars that fit our trucks well?
  11. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    im in the process of wiring up 4 kc 69 series long range lights to the roof, 2 procomp 6x9 lights to the bumper along with a set of 55 wat driving lights to the grill on my 87 p/u. gunna be nice and bright for the backroad driving. i think im also going to do the headlight relay thing posted above.
    nad- i think smittybuilt made one and theres the one you can get out of lmc.
  12. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I just bought the cheap, black 80 watt Pro-Comps. ~$70 with wiring kit. Bright and haven't had any problems.
  13. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Definetely rewire and eventually you'll want more alternator output, especially if you add in a CB. For extra lights I added LightForce 170s. I sometimes get fog (predawn) so I leave on the yellow lens, and then for daylight at night, I put on the clear lens'.
  14. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    bought 5 kc's used for $80 to my door.. 1 has a broken lense..
    got 4 of them on my front bumper
    5 on rollbar are broke... walmart sells some for $10 each.. I know someone that bought them and loves them..... so gonna put 5 of them on the rollbar this summer... also gonna make some mounts.. I got 2 eagle eye ii's that I am going to mount on my rollbar backwards this summer too.... someone wants to flick their high beams at me... :haha:
    also dont forget that you need relays when you hook up lights....
    what is everyone using?
    I was told to use relays from a car in the junkyard. My father showed me that on our 1996 Jimmy (just sold it) that it has 4 relays right on the firewall...
    I went to a junkyard and searched for about 2 hrs...
    2hrs and $15 later I came home with this....
    8 relays and 16 fuses..... out of a 1989 olds 88... nice thing is that the relays can be bought from any local parts stores if they go bad.. or junkyard for that matter....
    I have it as a big mess right now but am going to clean it up once I get my crew cab in the future....
    I have 2 lights on the rollbar to 1 relay... 2 more to another... then they goto the light switches... 30A relays so I am good with 2 per relay.... got plenty more relays for other lights and fuses inline with the lights and other stuff if I wish....
    also under the hood... I was able to use 2 bolts that already existed.. believe it was actually studs that had nuts on them... this cab is off of a diesel... and had a plastic inner so I believe that is what they were holding on.... but that is why it is on an angle....
    my switches are here...
  15. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I have 10 cheap ones from HF - $10 a pair on sale - that I use as uility lights to set up camp,change tires, etc. They have actually worked great and who cares if one breaks at that price.
  16. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    my light setup and custom made switch box with realays that powers all my lighting.
    so here you can see the replaced headlights with 2 floods with 2 bulbs each, square spots pointed outwords, two yellow fog spots, and two white spots, also some crappy driveing lights off my brothers old car wired to a ground contact switch under the hood, i always have light, :D
  17. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    That kind of bargain is so cool:D
  18. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Yeow
    ET.
  19. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    I use to have two hella driving lights under my bumper and two KCs on top of my bumper.
  20. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    unless you plan on doing high-speed desert racing... do you really need extra lights? I know I never have...
    j
