what locker up front?
Discussion in 'The Garage' started by DesertDueler, Dec 22, 2002.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    What are you guys using? I used a lock-right with 35s in my Jimmy, but not sure if one would hold up to 38s. It is for a 10 bolt front. I dont want to hear go with a dana 60 either, someday it will get one.
    Thanks Dan /forums/images/graemlins/burb.gif
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    seeing how your in Arizona, you wont be in much Mud, locker on a half ton front in dry stuff is gonna be kinda rough...... but.... Stick with the strongest, Detroit.
  3. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    I'm running a D-44,. Strength is about the same. I have a Lock-right W/ 37 MT/R's. I broke a alxe shaft on bump dump at Blazer Bash. I ran the rest of the day w/ the broken axle shaft, on Hell's Revenge.The locker held up fine. I'm still running it. I bought it used. It was used w/ 35's .It had a couple of years of use on it before I got it.
    Later Ed /forums/images/graemlins/thumb.gif
  4. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I have a D44 front with 4:56s and 35s. I just put in a Tru Trac and I like it a lot. What do you have in the rear? Because thats my problem, I have a Tru Trac rear as well... limited slip front+limited slip rear=lots of brake pedal on and offs to get both to lock up. If you have a locker rear, the TruTrac will be great. If you dont, lock the rear then get the TruTrac will be great. Like I said, I like the front TruTrac... I just need to lock my rear up a little more solid.
    Mike
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am only running 32's with my lockright front, but the previous owner ran it with 35" MTR's with no problem. /forums/images/graemlins/tongue.gif (Dan, no you can't have it back)
    Personally if you hadn't given me a sweet deal on your old front end and I didn't go LS I would have went ARB or Detroit. If you don't have the cash, you can sell me some more parts. /forums/images/graemlins/laugh.gif I only dropped $1200 for your old parts this summer. I probably should have just bought the whole truck. /forums/images/graemlins/smile.gif Oh well. On your Burb, I think ARB would be cool. A little pricey but very cool and nice if you need to turn it alot when you need 4x4.
  6. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I was thinking about looking into the new electric locker. I think Eaton is making it, would like something like that for my D60.
  7. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    What else fo you need Harley? BTW hows that tranny doing? Anyways I am looking into a ARB for it. The burb is alot bigger than the Jimmy so I know I have to be more careful. That and now since I am on 38.5s /forums/images/graemlins/grin.gif I am trying to decide on alloy axles and CTM joints, or a custom dana 60. Mostly it will be used for sand (glamis), and a little wheeling since the burb will have a hard time fitting in places out here. I should have keep the 60 I had, but ohwell.
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The tranny is running good. (knock on wood) I am leaving for Colorado on the 6th so it has a long haul ahead. There are lots of things I think I need part wise, but I have no cash for them. I just got my rear shock relocation kit from 55Willy so I am going to get that welded in ASAP so I will have some rear shocks again. Good luck with the Burb and those 38.5's and 1/2 ton's. If you go to alloys in them you should last for awhile.
    I am ok for now on my 10 bolt front, but when I get the 37's I want I will be really worried about it unless I get alloy axles & CTM's. Later
    Harley
    P.S. What did you do with those sets of 35's & 33's you had? I could use some mud tires cheap for CO. /forums/images/graemlins/wink.gif
  9. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    I still have the 35s and 33s. Not going to sell the MTRs, but want to sell the 33 MTs. Let me know.
    Dan
  10. NE-RokToy
    NE-RokToy Registered Member
    Dec 24, 2002
    39
    Omaha NE
    If I had the money i would run an ARB, if not stick with a lock right. You will break a axle shaft before you hurt a locker (unless its a detroit then you may blow up the locker because you break an axle)
  11. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I'd be looking at 30-spline axles for 10-bolt before I sunk money into a locker. Either aftermarket or 89-91 Blaxer/Jimmy/Burb.
    Actually, I'd try welding it up first, so see if I like it /forums/images/graemlins/smirk.gif Then I could make a better decision as to locker, spool, open, etc.
  12. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Well considering I use to run a spool in the rear of my jimmy and a locker up front, I know how it will feel. As for 30 spline axles, it isnt going to make it any stronger since they use the same u-joints, and that is what breaks 99 percent of the time.
    Dan
  13. u2slow
    May 9, 2001
    2,217
    BC Canada
    'nuff said! /forums/images/graemlins/grin.gif
    Reason I cited the 30-spline upgrade would be to let you get into the strongest largest/aftermarket shaft available if this kind of breakage was experienced:
    Of course, the newer 30-spline stock shafts would be an interim solution.
  14. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    All the tech reports I have read say to use a selectable locker up front.
