What lubricant are you using in your Locking Hubs?
Discussion in 'The Garage' started by JK5, Mar 21, 2002.
  1. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I just cleaned up my Warn hubs and there ready for installation, what lube do I use to put into these hubs!
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    The same question was asked awhile...I'll see if I can find it.
  3. UseYourBlinker
    Jun 7, 2000
    11,117
    No luck.. I've seen peep's use anything from Marine wheel bearing grease....to a spray lube.
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I use a very light coating of marine grease.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am using light coats of grease in there. Not globs. Marine grease is best, because it repels water.
  6. Den
    Den 1/2 ton status
    Jan 12, 2002
    142
    Arkansas
    WHEE BEARING GREASE??never heard of that... I have always used straight 30 weight oil in auto locking hubs and 90 weight gear oil in manual hubs... have never had a problem .....cant use the 90 in auto hubs... too thick...they wont actuate....
  7. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I use Blue Marine WB grease. Not too much just smear it on hte moving parts! Works fine last a long time....
  8. surg82k5
    surg82k5 1/2 ton status
    Feb 7, 2001
    416
    San Antonio,Texas
    Wouldn't any grease repel water??
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    What I meant was that this grease (from what I understand) doesn't get affected like normal grease. I have had normal grease get mixed with water, and the grease turned a whiteish color and was nasty and runny. Marine grease will not do this.
  10. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    Marine grease works for me.
  11. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    Just a thin coat of good waterproof marine type grease. I use Chevron Heavy Duty NLGI #5 Red and Tacky, very resistant to water contamination.
    Will
  12. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    One additional thing, I always apply a small bead of blue RTV around the outer lockout assembly just ahead of the o-ring to further help prevent water infiltration. Figure it can't hurt.
  13. NoRulz
    NoRulz 1/2 ton status
    Feb 6, 2001
    388
    Mesa, AZ
    WD-40
  14. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    I used heavy globs of Marine grease, not probs engaging hubs and no water gets through to the bearings, at least from that side.
    White Knight
  15. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I installed my Warns a little while ago, but from wha tI remember they are already greased and you shouldn't put any more grease in them...did you just get them, or did you take some old ones apart and clean them out?
  16. greg83k5
    greg83k5 1/2 ton status
    Nov 2, 2001
    230
    space sity houston, texas
    sea-doo synthetic marine grease. it's for the PTO on my jetski. it also works well in the hubs and such...
    greg
  17. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I have a bunch of that and that has got to be the stringiest stickiest stuff known to man.
  18. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    The hubs I have are about 10 years old, so I cleaned them and tried some marine grease, works good! Thanks everyone!!!
  19. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I pull mine every once in a while and soak them in ATF, seems to work so far!
  20. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Also, I always apply a small dab of sealant to the back side of the heads of the bolts that attach the hub. I have found that watter will seep in around them if they aren't sealed.
