what makes my steering do that rerurn to center thing?
Discussion in 'The Garage' started by fright89, Jan 31, 2003.
  1. fright89
    fright89 1/2 ton status
    Sep 27, 2001
    279
    boston
    how do i get mine to do it again?
    new steering box,tie rod,connecting rod and stabilizer. all helped my front end but it still does not return to center comming out of the curves and it wanders alittle.
    any help. thanks
  2. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Caster.
    Sounds like you need MORE of it......
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Wandering can be caused by your toe not being right.I think caster angle has a little to do with return to center .
    Setting your toe might fix both your problems /forums/images/graemlins/thumb.gif
  4. fright89
    Sep 27, 2001
    279
    boston
    is that an easy adjustment? I will dig out my manual and take a look or let me know. also doing a search .
  5. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Toe-In / Out is easy (I'd still take it to a shop with a real machine)...
    Caster is not as easy. With a solid-axle truck the only way to rotate that steering axis is to install shims under the leafsprings....my guess is you installed a lift kit and it changed your caster angle???
    A good alignment shop can do the toe-setting, and give you a measurement on the caster. Most of the trucks like ours want anywhere from 4 to 6 degrees of caster for a stable highway ride and that "return to center" behavior.
  6. fright89
    Sep 27, 2001
    279
    boston
    the lift is old. i did not put it on. it a 3'' i think with blocks in the back /forums/images/graemlins/frown.gif it used to be fine but that return to center seemed to slowly fade away.
    it is above freezing today in Mass. first time in about two weeks, so i am going out to take a look and do a little work on the blazer.
    it will get new springs soon, loose the blocks. could the front springs wearing out change the caster?
    i willl look at the shims too.
  7. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    You mentioned that you replaced the steering box, could the adjustment just be too tight? /forums/images/graemlins/confused.gif When I re-adjusted my steering box I lost all return to center so I backed the adjustment off a little and it came back. It wasn't hard to turn or anything, just didn't return to center /forums/images/graemlins/tongue.gif
  8. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    The return to center feel is a combination Caster and Steering Axis Inclination.
    Caster is the tilt of the upper and lower ball-joints, forward or back when viewed from the side. Positive caster is when the upper joint is behind the lower (axle houseing tilts back slightly). G.M. specs for us is a whopping 8 degges, that ALOT.
    There are 3 ways to adjust Caster
    - A off-set sleeve for the upper-ball joint stud can be installed.
    - A tapered steel shim can be installed behind the spindle
    - A tapered steel shim can be installed between the axle houseing and leaf-spring.
    Steering Axis Inclination (SAI) is the arch of the steering knuckle as it travels from stop-to-stop. When viewed from the front, the upper ball-joint is set in-board slightly, causeing the knuckle to swing on a slight arch, the top of the arch will be streight ahead, and the lower part of the arch will be full steering lock left or right. The weight of the vehical will try to pull the knuckles to the top of the arch (streaight).
    SAI is not adjustable and is cast into the axle houseing.
    Proper equipment is needed to preform alignments.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    isnt there a torsion bar in the mix as well?
  10. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    no torsion bars on the 73-91 blazers. there on the 88 up pu's and 92 up blazer/burbs.
    I noticed your kenworth pic, you a driver??
  11. evilandangry
    evilandangry 1/2 ton status
    Dec 29, 2002
    105
    Norwood, NJ
    Has the arch gone out of the front springs? does the truck looked "jacked up" in the back? This could cause the problem.
  12. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I think MJ was talking about the torsion bar inside the PS box. /forums/images/graemlins/thumb.gif
