What Master Cylinder are you running with your DANA60 front and rear disks?
Discussion in 'The Garage' started by mrdrinksalil, Jan 26, 2007.
What size master cylinder are you running with your Dana 60 front/rear disk brakes?
  1. 1 & 1/16"
    0 vote(s)
    0.0%
  2. 1 & 1/8"
    0 vote(s)
    0.0%
  3. 1 & 1/4"
    3 vote(s)
    23.1%
  4. 1 & 5/16"
    4 vote(s)
    30.8%
  5. Hydroboost
    5 vote(s)
    38.5%
  6. Other- Specify
    1 vote(s)
    7.7%
  1. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    1 1/16 ?
    1 1/8 ?
    1 1/4 ?
    1 5/16 ?
    Hydroboost ?
  2. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    89' V3500 Hydraboost setup. Don't know the bore size.
  3. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    '83 C30 hydroboost...works really good!
    Rene
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Do you run a prop valve?
    Ira
  5. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    Factory combo valve. My fronts and rears lock up at pretty much the same time...
    Rene
  6. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Don't know the size but the factory master cylinder and factory prop valve with no troubles. Been running like this for about 4 years now.
  7. HEAVY METAL
    HEAVY METAL 1/2 ton status
    Jan 10, 2005
    386
    Maple Ridge B.C. Canada
    i ahve that exact setup on my shop floor..... man i got to get that in there...:(
  8. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    131
    The stock 1/2 ton master cylinder (whatever size that is). My brakes work awesome :D
  9. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    What about those with 1/2 front, and 14bsf, or ff, with discs?
  10. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    84 3/4 master and hydroboost. stock proportioning valves. works perfect.
  11. greyhoundjc
    greyhoundjc 1/2 ton status
    Jan 23, 2005
    127
    Georgia
    After I did the disc swap to the 14ff with the caddy calipers, I used a m/c from a '76-'78 eldorado and it works great. Will lock up my 37's really nice.
  12. lurtch-k20-(78-90)
    lurtch-k20-(78-90) Registered Member
    Nov 8, 2006
    55
    Troup, tx
    SO with this in mind stock eldo m/c and prop valve should be included in the RR disk brake build kit.
  13. sandawgk5
    Oct 28, 2003
    6,881
    Only if you run a vacuum booster. That MC will not work with the Hydroboost units. For HB you need to use a MC that is in a HB application.
    Ira
  14. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    stock 1979 3/4 ton camper special master cylinder/booster, stock prop valve and aftermarket adjustable rear proportion valve. All stainless steel braided flex lines. Locks up my 39.5's on dry asphalt no problem.
  15. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    I'm putting in a hydroboost kit :D :saweet: :woot: !!!
  16. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    i believe the one i finally stuck with was the 79 k30 MC. with the 60 i can finally lock up my tires.
  17. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Stock. no problems ad stops great.
