What method do you use to remove frame rivets?
Discussion in 'The Garage' started by gambit420s, Jul 31, 2005.
  1. Drill
    8 vote(s)
    10.1%
  2. Air chisel
    27 vote(s)
    34.2%
  3. Big ole Air Hammer
    6 vote(s)
    7.6%
  4. Torch
    20 vote(s)
    25.3%
  5. TNT
    18 vote(s)
    22.8%
  1. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    After drilling out two of these, i switched to a small air chisel but that didnt quite work for me. so i broke out ths thing... 15-20 seconds each and theyre gone :D :D
    when in doubt use a bigger hammer....
  2. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    i use a cut off wheel in a air die grinder or a right angle air grinder and cut two slots that looks like a "plus" sine( + ), i try to cut down to the frame or bracket without gouging the frame or bracket then i air chisle it. its much easier to chisle four little pieces then one big rivet head. then sometimes the rivet can be hammered out, if not then i use drills to releave it so it can be hammered out. i use a 1/8 drill in my right angle air grinder with a 1/8 collet and i drill out the center to just past the thickness of the frame or bracket, i dont drill through so i can use the bottom of the hole the use a punch on. the air grinder will drill it at a fast rate so it goes pretty quick, then i use a 1/4 drill and if necessary a 3/8 drill then a punch to knock it out. thats my method, it works for me.
  3. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    Cold Chisel--on steroids!
    I used to use a "masons" chisel with a 5lb hammer to chop rivets off frame brackets...until I saw a guy at the junkyard use a all steel camping hatchet and a hammer!--he put the hatchet between the bracket and the frame,and gave it 3 or 4 good whacks,and the rivets sheared right off,the brackets were not damaged hardly at all(nothing bolting them to another frame would not fix anyway)..
    I was amazed how good it worked!--I'd wear a face sheild if you try this at home!..one reason it works well is because the handle of the hatchet keeps your hand out of the line of fire,and your not scared to give a good blow with the 5lb hammer!.. :rolleyes:
    I took this idea one step higher!--I had an old logspilitting wedge that had an "eye" in the center for a handle,like a hammer head does--I welded a peice of pipe to it 18" long for a handle,and I hit it with a 5lb ball pein or sledge hammer HARD and it only takes one or two whacks to shear the rivets!--If you use it like an AX its pretty effective too--I find it invaluable for "demolition" of vehicles your cutting up for scrap!--sheet metal is quicky cut away from body bolts,and sheet metal screws with boogered heads are no problem..just use "Thor's Hammer" and they go away FAST!.. :haha: :D :crazy:
    Of course,a torch works nicely too,but oxogen is expensive,and cant be bought here on weekends(place is closed sat and sun!) :mad: ..so brute force prevails where torches have failed!.. :crazy:
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Cutoff wheel and an air hammer. The grinder wiht the cutoff wheel did most of the work quickly.
  5. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    Big Air hammer. Takes like 10 seconds or less per rivet. Then I change bits to a punch and use the air hammer to punch them out. Don't buy a cheap one they suck. Buy a "long barrel" hammer and then you too will laugh at frame rivets :D
  6. dyeager535
    26,982
    191
    In the wrecking yard? Small drill bit through the rivet, then cold chisel to break the head off.
  7. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    :haha: :bow:
  8. RSNHELL
    RSNHELL Registered Member
    Jan 17, 2005
    53
    SANTA ROSA,CA
    Grinder and punch :weld:
  9. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Tried the chisel and hammer thingy. it broke me off trying to get 48 rivets out. Then I tried drilling through then whacking the head of the rivet off. Then with th e grinder and drill and hammer. A little easier, but still time consuming and tireing. Then the air hammer and WOWEE. Hardly any time and little physical effort.
  10. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    X2 :wink1:
  11. blownout
    blownout Registered Member
    Jul 19, 2005
    18
    ont.canada
    get a hot?
    u need a big bore gun a nd some blow to get them there bolts out .
  12. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    A few years back I posted pics of my frame that had every rivet removed. In order to do so, I used a 7" grinder (to grind the head of the rivets followed by a hammer and punch to punch it through). If the 7" grinder didn't work, I would use a 4" grinder, if that didn't work (space constraints) I would used stepped drill bits, and if that didn't work, I used a combination of things and air chisel. No one method will work for all rivets due to location and space constraints.
    Just be safe in whatever method you choose.
  13. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    x3 :grind:
  14. gambit420s
    May 17, 2005
    294
    posted at 2:06 am.... gee i wonder what this guy was doing.... :surepal: :surepal: :surepal:
    ever notice how every coke/crack fiend says you need some blow/rock to get anything accomplished?? :haha:
  15. cbbr
    Jul 17, 2004
    14,681
    Troll. Read his other posts. :angry1:
  16. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Air hammer w/ chisel bit, and a punch bit after the head's chiseled off.
    The grinder method works good, but the air tool is 10X faster
    -Mike
  17. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i use a grinder/air chisle (depending on location of rivet) then a punch
  18. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Torch and only when I don't want to keep the bracket that is coming off. Put the flame on the bracket side rather than the frame side and let the bracket shield the frame. If you need to keep the bracket you can still do it with a torch, just don't hit the high pressure. Just let the heat wash it off.
    My most favorite method isn't in your poll.
    Gouging tip on the plas!!
  19. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    x4.
    i tried it with a cheapass harbor freight air chisel, and it was more trouble than it was worth.
    grind the head off
    hit the bracket sideways a couple of times to break it loose
    pull the bracket off
    use a BFH to push the rivets out
    never takes me longer than a few minutes, but, my truck is "only" 14 years old.
  20. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    Just in case you were curious, that is called a maul and is a must in my book for splitting firewood :D
