What mod first???
Discussion in 'The Garage' started by hidesertwheelin, Jun 14, 2005.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    What would you guy's do first? A dana front swap our a doubler. The truck will be used mostky for rock crawling.
  2. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    Axles should always be the first mod. Just my 2 cents. Of course, it'd be cheapest to do both axles and doubler at the same time that way you only need to change the length of your driveshafts (or buy one set of new ones) once.
    j
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Dana swap.
  4. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    If your referring to a Dana 60 then get the D60 first with a 14ff in the rear. Later in the game when you want to do other things that require 1 ton axles i.e. Big engine=Big tires you will already be set.
