what models can i get it from
Discussion in 'The Garage' started by chvymudin3388, Sep 15, 2006.
  1. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    im looking for an exact replacement rear axle for my 87 k5blazer. what models have it? 10 bolt or 12 but exact replacement.
  2. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    Buy my 10bolts I'm taking out of my 88K5. :wink1:
    Stock is a 10 bolt front and rear on a 87. I think they used them from 91 back to early 80's at least. they can also be found under 1/2 ton burbs and pickups as well.
  3. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    There are a couple things to consider for an exact replacement.
    Yoke
    Gear ratio
    brakes
    e brake style
    lug count
    All of these things can be handled pretty easy as long as you get the same ratio. Chances are you will have a pretty easy time finding one.
    Brakes can be swapped from the backing plates out so getting a different brake size is no big deal. Keep it or bolt your existing brake system to it.
    If it has a different ebrake system, You will need to swap the backing plates. At least that is what I did when I put a 77 12 bolt in my 87 K5. I can't remember if the ebrake system is dependent on the backing plates.
    If the yoke is a different size, your dline will not bolt up. You can get a conversion joint pretty cheap and you should change the ujoint anyways if you have it out. Also change the bearing and seals. they are cheap too...
    If you get a 5 lug axle, just put in your 6 lugs. they are the same so feel free to get a rear off a 2wd. You will have a much easier time finding one on a 2wd for cheap.
    I recommend getting a 12 bolt. its not much better than a 10 but if you are swapping, might as well go with the better axle... the only difference I found that was not "swapable" was the 12 bolt yoke was 1 inch closer to the the tcase. That meant the travel length of the dline has been shortened. most people would not let that inch bother them. I had a new dline made to a custome length but that was, primarily, because I had a cv shaft made for the rear.
    I think there were 10 bolts in the late 70's. maybe just for 2wd, I don't know. I also have an 81K5 that has a stock 12 bolt... For sure in the eighties. Again, you will have no problem finding one in the smallest of towns...
  4. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    ok but the thing is they have different leaf spring and shocks mounting areas and i dont want to have to cut and reweld. although i could go ahead and degree my rear end and make it where i dont need my wedges.
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    All 1/2 & 3/4 ton pickups, all Suburbans, and All K5s from 1973-1987 have the same spring pad spacing and shock mount locations. Suburbans and K5s go all the way to 1991 also.
    Ira
  6. sandawgk5
    Oct 28, 2003
    6,881
    You already have the parts take the time and just change out your ring and pinion and use the open carrier. The only problem with your current axle is a gov-bomb that fizzled rather than exploding right? So remove that carrier, take off ring gear, install ring gear on the open carrier you have and put the carrier back in. Be sure to check backlash and carrier preload and then run a pattern. The pinion should not need to be touched at all. It is not hard at all take your time and you will be fine.
    Ira
  7. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    i dont really wanna mess with the back lash and all that plus my axle has some deep wear marks where the bearing rides
  8. sandawgk5
    Oct 28, 2003
    6,881
    OK. My previous post list what you can find a axle from.
    Ira
  9. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    i dont wanna mess with the back lash plus i dont have a dial indicator
  10. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    I've got an 87 burb I'm parting with 3.73 gears; what gear ratio do you need?
    Jimbo
  11. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    thats what i need is 3.73, but how much do you want i can get a 12 bolt for like 250 but i dont remember the ratio of it.
  12. Jimbo*
    Mar 8, 2005
    1,420
    roswell, new mexico
    PM "bigred81", He's in Kennedy, and has a shop and can help you out.
    If he can't, I'll take $150, and can get it to bracketville for you..
    Jimbo
  13. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    wheres bracketville? i dont think i can pm im not a paying member
  14. Jimbo*
    Mar 8, 2005
    1,420
    roswell, new mexico
    Ok,then look him up on the member list, and email him.
    Brackettville is about 100 miles west of San Antonio.
    Jimbo
  15. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    is there any thing wrong with it?
  16. Jimbo*
    Mar 8, 2005
    1,420
    roswell, new mexico
    Not that I know of, drove fine. I'll pull the cover and check it out.
    Jimbo
  17. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    ok thanks another thing is it open? gov loc? or posi? idont really care though lol i just want to be back rolling. lol
  18. Jimbo*
    Mar 8, 2005
    1,420
    roswell, new mexico
    Problem. The build sheet says 3.73 with gov-loc; pop the cover and it's a 3.42 with a gov-loc. Sorry bout that.
    Jimbo
