What mods must be done to my truck...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by yunit, Jun 22, 2001.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    What mods must be done to my truck for a 6" lift to work properly? My truck is an 87 Jimmy Sierra Classic, front quad shock setup, 700r4/208 combo. I am thinking of doing 6" springs up front, shackle flip in the rear with revolver shackles and maybe a 3" spring in the back. Within the next 2 months I plan on installing a D60/14B setup and will have drive shafts made up to go with the new axles. Well let me know what you guys think, I am getting very antsy about this and need to come up with a definite plan soon. Thanks, Pete.
    1987 Jimmy Sierra Classic, Palisades Park, NJ 07650
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    What is going to be the primary duties of this vehicle? Is it going to be strictly a pavement pounder, strictly trail, 50/50, 60/40, 90/10, etc.? This will help us decide what you will "need".
    If you didn't built it yourself, how can you call it yours.......?
  3. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    This will be a 50/50 truck, I will need it to be highway friendly. During the winter I do alot of highway driving to a winter house that I rent, which is about 130 miles away. I want to make it as offroad as I possibly can.
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Well I just put a 6" lift on my 87 Blazer...
    If you are gonna get a d60 or even if not get a 4" w/ shakle flip for the rear... it should be level. The d60 perches are a bit hight if I reacall correctly and you can add an ORD zero rate spacer to the rear if it isn't even.
    But go 4" spring and flip, 8" front spring, drop pitman arm, 4-6" raised steering arm, Longer rear d-shaft by about 2", probably go w/ the superlift 1" spacer for the front shaft, ORD disconnect/correction kit for the sway bar... steering box brace from ORD, Longer brakes lines... uhh... think that is about everything in a nut shelll... someone add to it if I'm wrong... feel free to pm me for pics or any questions w/ your lift
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
