What motor should I get.
Discussion in 'The Garage' started by jhellwig, Jul 15, 2005.
  1. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    The mtor in my blazer decided to let go today. Well, it still runs but makes a weird whistling pop back through the intake and knocks.
    I am planning on upgrading to a turbo400 ,208 or 241 or 205 or doubler205 or something with the tcase and d60 14bff combo.
    I was considering going with the 350 H.O that gm preformance has. I plan on doing mud boggs mostly with some trails. Probaly not any rocks.
    Just woundering what everyones opinion is on the motor choice. Money is not to much of an object as of now.
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Well, if money isn't a big issue, I'd go with a built 383 stroker. The reason for staying with a small block is because they rap up quicker then the big block does and that's a good thing in mud.
  3. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    The 350 H.O. is a good motor but if you have a fairly good knowledge of engine building you can make alot better hp and tq for the same amount of money. For example you could buy the gm goodwrench 290 hp 326 ft lb 350 then throw some dart heads on it and have a 380 hp 400+ ft lb 350 for about 300 bucks more than a 350 h.o.
    330 hp is a huge difference over stock and you'll feel it every part of the power band. It'll have about as much hp at 2000 rpm as your stock motor had at 5300. A good Mudder is nothing more than good power and tires.
    the H.O. should get the job done with power to spare.
  4. royjones
    royjones Trucker upper Premium Member
    Jul 6, 2005
    629
    6
    somewhere close to ya
    allrighty then
    there is no sub for cubic inchs. a big block is the way to go :D
  5. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    I don't want to feed one though. And that moto is overused on this forum.
    I could get one of those 572's :D :D :D :D if I was rich and had a death wish.
  6. royjones
    Jul 6, 2005
    629
    6
    Hello
    Hay man so what you are saying is that you are wanting info on 350 ci motors. crate motors what about a jasper engine. or are they just one step above a autozone engine.They also have performance engines. How about edelbrock crate engines they have a bunch of moters with diff horse an tq ratings. I went to there websight an got a free catalog with these engines in it . I hope i helped a little :o
  7. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    :thinking: ..i know where there is a 426 hemi, all ready to be installed... :thinking:
    that would be fun in a k5.. :D
  8. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
  9. 79cheyenneblazer
    79cheyenneblazer Registered Member
    Jul 21, 2002
    68
    Jasper,Indiana
    There's no replacement for displacement, go big block :D :D
    Also about the "Jasper engines", living here in Jasper, Indiana I would not reccommend their engines, they have a rate of 1/3, one out of every 3 engines they build go out, and people in Jasper prefer not to go to them, its always the people out of town that buy up their stuff, just a little insight about Jasper engines and transmission.
  10. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    I recomend a Brad Anderson BA-98 engine. Most of the teams in Top Fuel run them. One of these should you get you through a mud pit in about 4 or 5 seconds :D.
  11. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
  12. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Its not that hard to build a fairly reliable 383 with 425-450HP and 450 lb. ft. torque. That will get you through the mud. GM sells one ( I believe its a zz383, 425HP 480 pounds torque with 6000RPM redline). That would be the way to go. Im sure theres many reputable engine shops out there that will build something similar with a warranty.
    I run a built 383 putting out about that much power in my 73 K20 and love it. I just know that the TH350 isnt gonna last long before I need to rebuild it to make it handle the power. :eek:
