What nobody else has this problem? Front passenger side body droop.....
Discussion in 'The Garage' started by 4GUNZ4X4Z, Jul 26, 2003.
  1. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Hi my name is Michael and I have front passenger side droop. About 2.5"s. 1" due to my core support. The other 1.5"s due to my leaf pack on pass side is flating out. Why only the pass side and not both equally you ask? Good question, I think it has something to do with my drop pitman arm being on the driver side causing the drive side to see less flex. Truely out of all honesty I dont know why, but it really hurts my feelings to see it lean so much to one side. Solution you ask? Well I've put some serious thought into it and the best idea that I can come up with is as follows. Run 38psi in the front pass side tire, run 22psi in the front driver side tire, run 22psi in the rear pass tire, and finally run 14psi in the rear driver side tire. I think this would work out great in making the truck appear to set level. Yes some of you right now are wondering what kinda of uneven wear your tires will get. Well simple... just rotate them every 250 miles or so. Oh and do not I repeat do not forget to adjust the psi in each tire after rotating them, it kinda defeats the purpose.
    Anyone else have any suggestions?
    Oh and one more thing... Who else has passenger side body droop?!? /forums/images/graemlins/angryfire.gif
  2. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    Re: Front passenger side body droop......roll call!!!!!!
    hey you should go oval track racing...your tire pressures are close for turning left /forums/images/graemlins/thumb.gif
  3. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Wow, I never notice it before, but the left one does hang lower than the right! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  4. Aquaman
    Aquaman 1/2 ton status
    Apr 21, 2002
    337
    Kansas City, MO
    sweet! I always thought that I had tweaked my frame or something. I'm glad it's normal!... err w/e it is.
  5. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    /forums/images/graemlins/thinking.gif Really... thats wierd my right one hangs lower... /forums/images/graemlins/thinking.gif strange.... I think you might be a freak... /forums/images/graemlins/thinking.gif Does anyone else's left hang lower or is TruckNutzDude just a nut? /forums/images/graemlins/thumb.gif
  6. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Yeah seriously for the longest time I did too. I 1st noticed it about 2 years ago and since then its got visually worse. Especially after I changed out my stock pitman arm for an aftermarket pitman made for a 6" lift. I've only got a 4" lift on the truck so I'm thinking this might be limiting the flex on the driver side. Doh
  7. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Damn I figured more people had this problem then just a few.
  8. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    My left one hangs 6" lower than the right, getting kind of hard to walk like that /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  9. 77Jimmy
    77Jimmy 1/2 ton status
    Sep 3, 2002
    661
    Atlanta, GA
    Yep, I have the same problem!!! I'm curious as to know why myself, and what I can do to fix it. /forums/images/graemlins/1zhelp.gif
