What oil do you guy's/gal's use?
Discussion in 'Pacific Region' started by UseYourBlinker, May 7, 2002.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    What oil do you guy\'s/gal\'s use?
    Just want to get an idea of what weight oil you Big Dawgs use? Also how many miles do you have on your engine?
  2. sarazk5
    sarazk5 1/2 ton status
    Feb 19, 2001
    713
    Sacramento, CA
    Re: What oil do you guy\'s/gal\'s use?
    Valveline - 10/40 in the Beast
    Castrol GTX - 10/40 in the Toyotas
    Castrol Syntec in the Stang
  3. Priest
    Priest Registered Member
    Apr 22, 2002
    95
    Tracy, CA
    178K miles
    Moblie 1 synthetic 20W/50 doesn't burn a drop
    Of course it a toyota 3.0L V6...that could explain something.
  4. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Valveline 10/30
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Pennzoil 10/30
    and I eithe have 120,000 miles or 220,000 miles. I'm really inclined to believe its 120,000 miles though. It's really clean for a '76.
  6. LiftedAssDodge
    LiftedAssDodge 1/2 ton status
    Apr 8, 2002
    412
    East Bay Area, ca
    mobil tri synthetic
  7. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    shell rotella (same stuff we use in the semi's)
  8. barbastard
    barbastard 1/2 ton status
    Dec 7, 2001
    289
    Pleasant Hill, California
    Castrol 10/40.....
    but, I was just in Texas visiting some family and my Unlce spoke EXTREMELY highly of "AMSOIL". he swares by it now, I checked out there website and I might purchase some of it. It is supposed to be the shiznit for oil and synthetic oil....
  9. xplosuv
    xplosuv 1/2 ton status
    Mar 9, 2001
    515
    Sacramento, CA
    Why does everybody use 10/40 - 10/30 ?
    I have always used the heavy 30 weight?
  10. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    156,000 and 10/30 Syntec.
  11. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    For some reason (which I can't remember) I switched from Quaker State to Penzoil when I built my motor in 94. I have used nothing but Penzoil 10W30 in all my vehicles since then. I also will only use Penzoil ATF in my trannies. Haven't had any problems with Penzoil.
    David
  12. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Straight 40 ,when its hot
    Straight 30,when its cold
    /forums/images/icons/smile.gif
    And Iv got around 150k on the engine
  13. Priest
    Apr 22, 2002
    95
    Tracy, CA
    (snip) Why does everybody use 10/40 - 10/30 ?
    I have always used the heavy 30 weight? (snip)
    Typically straight 30 weight is considered Diesel oil and if you look at the rating it is rated as such (various different detergents as well as a different heat rating, most people don't know what all those letters and number on the bottle mean). Multi viscosity oil is generaly considered more palletable for petro engines because of increased top end and startup oiling on a cold engine. That being said I ran straight W30 for years without any problems what so ever. It really comes down to what type of climate you live in. For this area (the valley) we don't see a big variation in temperature or extreme temps either.
    More importantly than what kind of oil is changing it regularly..every 3K or 3 months. I know that alot of newer cars with tell you that you only need to change every 5K but I still would go every 3K. As cars become more efficent the need for oil changes becomes less frequent (most oil break down is cause by contamination from blow by gasses) but I figure for the amount it costs me to change my oil I consider it an ounce of prevention.
    It used to crack me up with I would go to the refinery with my pop to pick up oil and I would see all kinds of different brands of oil coming out of the same place with different labels.
  14. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    20/50 Don't care what the weather is like. Thats just what I use
  15. Priest
    Apr 22, 2002
    95
    Tracy, CA
    Why aren't you over here cuttin'?
  16. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Valveline(sp?) 10/40 & Wix filters
    I perrty much change my oil before every road trip(almost).
    My K5 is not a daily driver so don't really track the milage between changes but I know it's way below 3K.
    I don't think it realy matters what oil you use(well besides the super cheep crap) as long as it get changed frequently yer good to go.....
  17. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    229k miles on the 400
    i use castrol 20/50 and it eats a quart a month.
  18. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    what kind of gear oil y'all use in the pumpkin?
  19. Burt4x4
    6,854
    Valveline 90w
    I heard rumors about the Sta-Lube brand not holding up to the heat verywell and it was recomended to use any 'major' brand instead...?? Don't have any first hand experiance with Sta-Lube causing an issue but I figured I can't go wron with Valveline so........
  20. delta9blazer
    1,646
    i've been hearing that i should use redline in there. anyone vouch for that?
