What oil do you run in your t-case np205
Discussion in 'The Garage' started by primerk5, Mar 16, 2007.
  1. primerk5
    primerk5 1/2 ton status
    Jan 13, 2001
    220
    Finksburg MD
    I normally run 90 wt, (gear oil) Though a friend says to run Trans fluid. I'm thinking gear oil is what should be in the t-case.
  2. sgarrison
    sgarrison 1/2 ton status
    Feb 4, 2005
    148
    Art's Bar and Grill Mt. Pleasant S.
    If its a cast iron case, like the 205, run gear lube. If its an aluminum case then trans.fluid should be run.
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    NP205 takes 80w90, period.
    I run Sythentic 80w90 Mobil 1 in mine.
  4. primerk5
    Jan 13, 2001
    220
    Finksburg MD
    Cool, Gear lube it is! Thanks
  5. dyeager535
    26,975
    "Run trans fluid" comes from the fact that later on that's exactly what GM did. (My '91 205 came that way)
    Makes it a bit less of a problem if the seals fail on an auto trans application, since the fluid won't be contaminated, but other than that, it's pointless to run ATF.
  6. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    I have a NP205 and a TH400. I thought the 205's behind autos should have trans fluid... I dont' think there are any seals between the tranny and the transfer to keep the fluids seperate. Now I'm confused...
  7. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I run ATF in the t cases. I would say 1/2 of the cases I have had in the past were oil and the other half ATF.
  8. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    I cant speak for the autos but my sm465 has a seal in the adapter to prevent its fluid from getting into it. The t-case side doesnt though. My truck is an '83 and came with the 465/205 setup. The factory manual says to use ATF in the case. I use synthetic 80-90w.
