WHAT oil does every body run ??
Discussion in '1982-Present GM Diesel' started by doctor4x4, Apr 27, 2003.
  1. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    did a search only 3 people had responded GOOD GREIF there has 2 be more then 3 people with an opion and experience so post up its good for fellow future searchers /forums/images/graemlins/thumb.gif
    so while you at it WHAT ADDITIVES do ya run in the oil ?? if any and
    WHAT Additives in the fuel ???
    Thanks the world is now a better place /forums/images/graemlins/wink.gif
  2. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    I think most people use shell rotella 15w40. Do a search further back, heres one post oil.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The visor on my '83 diesel parts truck shows SAE 30 is suggested above 0* C, and 15W40 down to -15* C.
    I've been using Castrol RX Super 15w40 up till now. The next oil change with be SAE 30. I'm going to save the 15W40 for my winter oil change.
    The low-sulphur diesel you get these days doesn't lubricate the injection pump adequately, shoterning its life. The additive provides the necessary lubrication, aids in separating water, prevents fuel gelling in winter, and boosts cetane value of fuel (for more power).
    I was using the Stanadyne fuel additive since I got the truck (8 months ago). I ran out and couldn't find the Standyne again, so I'm using Gunk diesel additive now.
  4. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I used to run rotella T.
    Now I run Mobil Delvac, mostly because it comes in 10 quart containers.
  5. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    we run Mobil 1 Delvac- full synthetic in our Duramax-
    No additives have ever been in any of our rig's...well- okay- we do run a fuel stabilizer in the winter months.
    Brandy
  6. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    chevron delo-400 15w40
    and also gunk diesel additive in the fuel.
    anyone running redline products either in the fuel, or even thier water additive for cooling?
  7. MudNurI
    Jul 15, 2001
    2,113
    VT
    tons of guys at TDP are using Red Line additives.....
    Cant say as though I know of anyone personally using them, but we dont have "old" diesels- and we dont normally keep them long enough to worry about longevity.
    Brandy
  8. doctor4x4
    Jan 22, 2002
    1,450
    Los Angeles
    now that more like it /forums/images/graemlins/thumb.gif
    any more ??? - different ??
    THANKS ALL !!!!
    /forums/images/graemlins/usaflag.gif
  9. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    Just started running Delvac1, the local Traveller's America had it miss-priced as Delvac 1300! Something like 9 or 10 bucks a gallon, normally it's around 5 bucks a qrt.!
    I bought all they had, 10 gallons of it! I only put about 10-15K a year on the Blazer and I shouldn't have no problems with this oil lasting all year. At the worst it should be good for 6 months. Really, it is one of the best oils out there. Good stuff.
    I'll be running it for quite a while! /forums/images/graemlins/thumb.gif
  10. DieselFreak
    DieselFreak Registered Member
    Mar 13, 2003
    71
    Aaland, Finland
    well here in finland were I live it's temperature changes from 20 - 25 degrees centigrade in the summer to -20 degrees centigrade in the winter..although im running a 10W-30 oil and that works great.
  11. u2slow
    May 9, 2001
    2,217
    BC Canada
    Oil weight aside, make sure the oil you use is rated for diesel use - identified by CF/CG/CH service category instead of SG/SH/SJ. Its made to deal with extra soot/fuel that ends up in the oil of a diesel engine.
    When I first got my diesel, I was going to use the 20W50 I had sitting around until I read the bottle and did some searches on the Web.
    http://www.api.org/programs_services/quality/oilchart.htm
  12. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    i use penzoil heavy duty 15w-40.. it seems good, dont use additives, but should i? what do they do?
  13. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Rotella T 15w-40 in the crankcase.
    Power Service diesel fuel additive in the winter, to prevent gelling, and once in a while in the summer, to help clean the injectors.
    Casey
  14. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Rotella T 15w - 40 in the crankcase. No additives in the oil, but Stanadyne in the fuel tank!!
  15. doctor4x4
    Jan 22, 2002
    1,450
    Los Angeles
    cool Rotella 15-40 it is :-)
    Thaks a million guys !!!!!
    i got the factory manuel
    if you guys ever need any info
    in return
    Randy
  16. Stormbringer
    Stormbringer Registered Member
    Dec 20, 2002
    6
    Cleveland Ohio
    If you don't allow such a blatant commercial post, I'll understand if ya pull it. Thanks for the time.
    [edit] Thanks for understanding...[/edit]
    Tom /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif
  17. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Ive been running CaseInternational 30 weight, the same stuff we use in our tractors at the farm. We buy it by the 5 gallon bucket. I ran it in my C10 Scottsdale till i killed the 700R4 towing, and now im running it in my K15 Sierra
