What oil filter you running?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fr8train, Sep 11, 2001.
  1. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Exactly what the topic says. I am running fram. I am wondering what else is out there and your feedback on them.
    <a target="_blank" href=http://community.webshots.com/user/thatguydrew23>http://community.webshots.com/user/thatguydrew23</a>
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Fram is BAD.........they are poorly made and don't stand up very well. Go with a good ol' AcDelco or a Napa instead.
    <font color=blue> MEAN DAD WITH TWO BAD KIDS<font color=blue>
  3. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    Oh, as all the years I spent as a mechanic I never saw as much engine damage, as that caused by a Fram! One of the most restrictive oil filter made. People can argue all they want but cut one open and you get real quiet. Napa Gold or Wix!!! Same thing, thats it, nothing else, no way.
    Displacement, cubes, and did you say you drive a riceburner???
  4. fr8train
    Aug 2, 2000
    1,712
    Maryland
    OK maybe I am going ot be changing that out tommorow. Any other suggestions?
  5. surg82k5
    surg82k5 1/2 ton status
    Feb 7, 2001
    416
    San Antonio,Texas
    I would say stick with NAPA GOLD!!
    Sergio
    Check out my new website. <a target="_blank" href=http://www.surg82k5.rockcrawler.com>http://www.surg82k5.rockcrawler.com</a>
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I run either Napa Gold or Baldwin - both are awesome flowing, with excellent filtration.
    Special thanks to those lost in NY, DC and PA
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  7. txguy
    txguy 1/2 ton status
    Sep 4, 2001
    114
    Round Rock (Austin) Tx
    I just put one of those larger fram's on mine. Does anyone know of a large capacity filter for the 305 in a 85 jimmy?
  8. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Baldwin makes one, but I don't remember the p/n off hand - Wix makes one too.
  9. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    I run a Napa Gold or Wix 'truck' filter. It is the two quart one. It will fit pretty much any small black chevy in a blazer/jimmy. Just go into Napa and ask for a two quart truck filter for a 19xx blazer.
  10. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Like most others I have been using NAPA Gold or Wix filters for a long time.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  11. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I run AC Delco b/c it's cheaper than wix and all those other high dollar ones, but it rated up there; not as good, but good enough. FRAM sucks. And yes, AC makes the larger ones too.
    Boss
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  12. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I have heard of the Fram filters internaly failing and alowing the oil debris that gets traped in a filter to reenter the engine.
    I use Wix/NapaGold (same filter)....
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  13. Emmettology 101
    May 9, 2000
    8,126
    FL
    I use either Hastings, AC or Pure One...... In the larger size.
    Mike
    <font color=green>"My K5 is purdyr than your sister!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  14. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    Mobil One, AC Delco, Purolator Pure One.....wouldn't use a Fram if they paid me.....Wix is ok also...
    Stuck?...Hell no..I still got some gas left..
  15. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Hastings...
    89 K5 Silverado
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  16. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I like the AC Delco's too. The AC Delco is a good buy as long as you adhere to recommended oil change intervals. The AC delco may not have as much filtering area as some (still better than Fram and the el-cheapo's), but it has more than enough for 3000-4000 miles of typical use. It's also rated good for burst strength and oil sealing (rubber o-ring on top). If you don't change your oil for 2 years or 15,000 you may have a problem, but not many filters will help out then. For the $, AC Delco is the way to go with normal oil change intervals. I don't always run AC Delco's, but I never run Frams anymore.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
  17. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I run a carquest filter on my Jimmy. For the Firebird I run a fram filter. Never any problems with the fram. I use it because it is easy to take off with that anti slip on the side. I change the oil in my firebird every two weeks, so I havent really tested the filter when it gets dirty.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  18. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    does any one ever use the kn oil filters
    high
  19. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Fram is awful. The big ones just suck in a bigger way. Do a search for the report that was put up on filters. You'll be surprised on the findings. I run either Wix or Napa Gold... [​IMG]
    9/11/01... "We will overcome"
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>www.chevycagal.homestead.com/steph.html</a>
  20. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    DO they make AC delco ones in bigger sizes?? I run AC delcos now&lt; i like the blue color, and that it is GM.
    Ben 87 Jimmy
    <font color=blue>Rust=Bad</font color=blue>
    <a target="_blank" href=http://www.bens87toy.alloffroad.com>www.bens87toy.alloffroad.com</a>
