What part do I need?
Discussion in 'The Garage' started by 84mudmachine, Mar 30, 2005.
  1. 84mudmachine
    84mudmachine 1/2 ton status
    Dec 23, 2003
    184
    Kansas
    I'm going to install a/c in the truck here soon, but I need to know what the bracket and selinoid on the quadrajet and that kicks up the idle when the a/c is turned on is called and possibly where to get one.
  2. 84mudmachine
    Dec 23, 2003
    184
    Kansas
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Junk yard???
    Wanted section maybe?
  4. 84mudmachine
    Dec 23, 2003
    184
    Kansas
    :D you think?
  5. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I meant maybe post in the Wanted section. Sorry.
  6. 84mudmachine
    Dec 23, 2003
    184
    Kansas
    I know, thats why I'm :D
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have one or a few of them, 70s 80s style it bolts to side of carb front left hand side with two screws
    you adjust it with a wrench it has a hex headed shaft where it contacts accel linkage front side they are common find them mostly on the early 80s caprice and such
  8. ssls6
    ssls6 Registered Member
    Jan 5, 2005
    86
    Dallas, TX
    Thermal idle control switch. It is part of the emmissions stuff.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    kicks idle up for a/c compressor kick in i like to put them on all my vehicles so i can de energize it before shutting it off so it wont diesel/run on when hot and such, i set idle screw on carb to lower than stock so throttle blades will shut down to lower than can idle with and use the solenoid to set my regular idle speed, flip it on, hit the pedal once, fire it up
    flip it off, then shut off engine, and wont run on
    isnt what gm designed it for but thats what i use them for,
