What part # for a turn signal combo lever?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nrose07, Mar 19, 2002.
  1. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    I found one cheap that is listed for 84-91 blazer/jimmy's. Suposed to be a replacement forpart# 25111260. BUT then it also sas 84-88 G bodies. Will this work in by 88' with a tilt colum?
  2. dyeager535
    26,980
    It should...'84 should be the change for the dimmer/wipers on the column, although I'm surprised wiring length is same for a Monte Carlo column as a K5.
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    It probably will because the columns are all pretty much the same. I got my turn signal lever from a '91 Oldsmoblie Cutlass.
